11-03-2019, 07:15 PM | #1 |
Newbie Join Date: Jun 2016 Location: NorCal
| torque twist?
ive been battling this seemingly forever now, and not sure where to even look anymore. the whole body on my (whats left of) SCX10 dips on the left/drivers side. This is the same side as the driveline/transmission. Ive tried cranking the spring on the right/passenger side to be super soft and the left/drivers side to as hard as possible, but it doesn't matter. As soon as I hit the throttle, it dips hard down on the left/drivers/driveline side. After a few minutes of driving the whole body just hangs low on that side and from that point forward. is it a link position or length issue? stock SCX10 deadbolt links, albeit worn down now. Could it be the axle housings and their orientation to the driveline/transmission? The internals are scx10 stock, but the housings are from OttSix which does give it a different angle. frame is BPC, as is battery tray and sliders. I don't want to tear it down to a pile of spare parts, and I don't want to just throw piles of parts at unrelated area's - but I do want it fixed. ideas? |
11-04-2019, 01:36 PM | #2 |
| Re: torque twist?
Ok, ive been doing a lot more research on my own and I have some idea's on where to start now. First, I need to look heavily at my upper links Vs pinion angle. Second, i'll try doing the transmission mirror mod. It's really more than just torque twist, as after a few minutes of driving the whole body shifts its weight down on that side. After I do the above mods ill take a video of what it looks like, assuming it'll still be problematic then. |
11-04-2019, 10:59 PM | #3 |
Rock Stacker Join Date: May 2019 Location: Boyertown Pa.
| Re: torque twist?
Are one of your wheels dragging on the inside? I had a major problem like you are describing. Turns out the wheels were rubbing. Check to see if something is rubbing.
11-21-2019, 03:28 PM | #4 | |
| Re: torque twist? Quote:
Do as you said, also mirror the transmission/skidplate and it eliminates the TT almost entirely. I ran stock shocks/springs with preload backed way off and 30wt oil, green slime on shock seals (rebuild with the newer X-rings). Sticking shocks can also cause the truck to not rebound properly and kinda get stuck leaned over whichever way is sticking the most. Good suggestion too. | |
11-21-2019, 09:50 PM | #5 |
| Re: torque twist?
That's why I got trx4 axles. They help a bunch to reduce torque twist. You might want to get a larger pinion too. Sent from my SM-N950U using Tapatalk |
11-22-2019, 05:04 AM | #6 |
| Re: torque twist?
Over drive gear in the front under drive the rear, no more TT.
11-26-2019, 10:51 AM | #7 |
| Re: torque twist?
I did OD front only, was plenty good. UD rear would have been nicer though due to more ring/pinion gear teeth engagement, but it never caused any problems for me in years of hard running.
torque twist? - Similar Threads | ||||
Torque twist | 63comet | Axial RR10 Bomber | 54 | 07-22-2016 01:25 PM |
ECX Temper Torque Twist Mod - Reduce torque twist | driftomaniacs | Scale Videos! | 0 | 05-14-2016 04:39 PM |
torque twist | dodgesavageone | Venom Creeper | 6 | 03-02-2011 11:17 PM |
Torque twist? | minnesotamudder | General Crawlers | 10 | 08-05-2010 08:16 AM |
