03-22-2012, 12:59 AM | #1 |
Newbie Join Date: Feb 2012 Location: Perth Australia
| Will a Tekin 35T be P-n-P on my OEM ESC ?
Hey there guys, sorry, im not a electronics guy at all with motors and ESC's, the propulsion of exp in the past has always resided in a bottle. With the Axial i have a 27T there stock. I could go a 55T Axial, but if i went half way there abouts with a Tekin or other brand brushed motor, is it a totally plun-n-play setup ?. Would i need another ESC ?. Thanks |
03-22-2012, 04:03 AM | #2 |
Quarry Creeper Join Date: Aug 2011 Location: United Kingdom
| Re: Will a Tekin 35T be P-n-P on my OEM ESC ?
It would work but would not be plug and play exactly. The Tekin motor would require you to solder the wires onto the solder tabs on the end bell of the motor. You could just de-solder the wires from your current 27T and solder them onto the Tekin motor and once done just plug the motor wires into the esc wires and you are good to go. |
Will a Tekin 35T be P-n-P on my OEM ESC ? - Similar Threads | ||||
Tekin FXR ESC Crawler Combo 35T Motor suggestions | bro_die | Axial AX-10 Scorpion | 38 | 12-24-2010 03:29 PM |
