03-28-2012, 07:38 AM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
| best mods to maximize scx10 crawling capabilities?
Hey guys, i have an scx10, and coming from driving a super, i've wanted to do a few mods to make mine a lot more comp capable, and i dont mind taking away from the scale look a bit. i already run no bumpers/fenders/rock sliders, have 2.2's with stiffer cut foams, 1/2lb on front axle 1/4lb on rear, battery tray relocated across the chassis on the front end, steel integy driveshafts and diffs, all waterproof, and other small things here and there. I love beefy trucks, so i dont mind pushing this to around 10lb if needed. im looking for ways to get more articulation (i've removed the bump stops and have longer alloy Duratraxx shocks), but with the current configuration my rear 4-link upper hits on the chassis brace that holds together the rear shock hoops. angling my shock in towards the center of the chassis would just soften my suspension, not give me more flex, correct? would lifting the chassis up an inch and angling the shocks work? I've been looking into a dig unit as well as i've seen how useful they are, but it seems if i flick my throttle i can kinda spin the tires and do a little fake dig... If i were to overdrive my front axle, would that give me roughly the same benefits of a dig, but without the actual unit? or am i just better off buying a reputable dig unit(for 2x the price of overdrive gears plus a new tx/rx)? what mods have you done to purely increase crawling performance of your truck? scale or not scale, doesnt' matter. |
03-28-2012, 07:43 AM | #2 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
Do the xr mod Sent from my DROIDX using Tapatalk |
03-28-2012, 08:01 AM | #3 |
RCC Addict Join Date: Apr 2007 Location: Murfreesboro
| Re: best mods to maximize scx10 crawling capabilities?
Stock shocks are just fine on these things and offer more than enough articulation. Too much more and you are lookin good but performing like garbage. Put battery and all electronics up front, weight the front tires a bit and then learn to drive and you will have all you can handle out of that thing!!! OH...and have fun! Matt |
03-28-2012, 08:39 AM | #4 | |
| Re: best mods to maximize scx10 crawling capabilities? Quote:
I still need to find some sticky weights for my front tires, all i have for weights are lead blocks i hammer into size. i mount a 1/2lb on top of the steering servo and the 1/4lb on the rear axle. What is the XR mod? that is some major steering. my alloy servo horn will definitly let me turn past the point where the stock hubs hang up on the axle. | |
03-28-2012, 10:08 AM | #5 |
Newbie Join Date: Feb 2012 Location: Columbia
It's xr10 knuckles and shafts
03-28-2012, 11:12 AM | #6 |
Pebble Pounder Join Date: Mar 2011 Location: St. Louis
I went with 4ws, using VP's 8 degree stuff and Rc4wd xvds the rock crawling is awesome. I just put dig on and an overdrive in the front. I am not sure about the dig or OD. I am going to give it a little time. The dig is a lot of weight on the rig the it is not as nimble now.
03-28-2012, 11:44 AM | #7 |
Pebble Pounder Join Date: Dec 2011 Location: Buffalo
| Re: best mods to maximize scx10 crawling capabilities? |
03-28-2012, 12:01 PM | #8 |
Xr10 shafts chubs and knuckles on ax10 axle housing. Sent from my DROIDX using Tapatalk |
03-28-2012, 12:10 PM | #9 |
Newbie Join Date: Dec 2011 Location: Norton
I just put a set of Pitbull Rock Beasts on my SCX10 and it is a crawling beast now.
03-28-2012, 12:11 PM | #10 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
Does it use the U-joint axles? Are the AX and XR axles the same width or are some mods necessary?
03-28-2012, 12:25 PM | #11 |
This mod give you tighter steering angle? I've done a similar mod on my drift car to give me a really higher steering angle.
03-28-2012, 12:35 PM | #12 |
It uses the xr10 ujoint axles. If you use long beef tubes you don't have to modify the shafts. I used standard beef tubes and cut down each shaft 11mm. It gives you 45* steering and infinitely adjustable caster. Sent from my DROIDX using Tapatalk |
03-28-2012, 03:28 PM | #13 |
Awesome. Thanks.
03-28-2012, 03:40 PM | #14 | |
Here's my mods, keep it simple, keep the weight low, mod for durability, drive well and you'll do well. Natedog's Honcho kit build | |
03-28-2012, 07:48 PM | #15 |
03-28-2012, 07:51 PM | #16 |
Quarry Creeper Join Date: Aug 2008 Location: back where I belong
Stupid question, but have you mirrored your trans? easily the best thing thats free..
03-28-2012, 09:51 PM | #17 | |
by far one of the best performance mods ive done was relocating the battery right behind the front shock mounts. it allowed me to take a 1/4lb off my front axle and put it on my rear, it really helps to plant the truck back in place when a tire lifts. of course its all much more noticeable with properly cut foams and nice tires. Does anyone use the 2.2 proline Badlands tire? its like a MX tire but super squishy compound. i love em! | |
03-29-2012, 05:53 AM | #18 | |
Sent from my DROIDX using Tapatalk | |
03-29-2012, 07:25 AM | #19 | |
Also, my 2.2s hit my shocks when fully turned to either side, is there a DIY method to widen my front axle a bit to get a bit more steering out of it? | |
03-29-2012, 08:29 AM | #20 | |
The xr mod also widens your track about .25" Sent from my DROIDX using Tapatalk | |
best mods to maximize scx10 crawling capabilities? - Similar Threads | ||||
Capabilities? | foratm | RC4WD Trail Finder 2 | 31 | 02-28-2012 01:58 PM |
New to crawling, what mods? | znaky85 | Losi Micro-Rock Crawler | 5 | 01-07-2012 10:26 PM |
Maximize Steering Angle | CHRIZAD | Axial AX-10 Scorpion | 16 | 07-21-2009 10:24 PM |
Capabilities | bigdodge88 | Tools, and Procedures | 4 | 02-18-2009 11:38 AM |
New to r/c crawling... Check out my Mods so far! | S10XtremeSR | General Crawlers | 26 | 03-22-2006 11:55 AM |
