04-30-2012, 11:54 AM | #1 |
Quarry Creeper Join Date: Mar 2011 Location: over there...
| wheel offsets and size
Ok so i just picked up a dingo kit and I'm already looking to add some 2.2 wheels probably some mayhem beadlocks . Things that i could not find info on .. Width of wheel ? 1" or 1.25" or if i go vp .7 ? Front/rear and why ? Running pitbulls tires . Next hub offsets I have many to choose from what works for the stock dingo and should i get more then one set just in case I change something down the road ? |
04-30-2012, 01:04 PM | #2 |
Rock Stacker Join Date: Jan 2011 Location: United States
| Re: wheel offsets and size
best look at some sort of lift before you go with the 2.2s i thought i was going to do the same thing with my cherokee that is already taller than a stock dingo and theres just no way
04-30-2012, 01:55 PM | #3 |
Pebble Pounder Join Date: Sep 2009 Location: "the valley"
dude, just buy the wheels/tires you want and use different width wheel hexes to get the desired offset, like stampede hexes(widest you can get) or touring car ones, etc. as for the clearance on 2.2's, youre either gonna have to do some major trimming, raise the body, or if need be (i wouldnt) put a lift on the rig.........btw, why not just go with a tall 1.9 to get the desired tire size, unless youre just going for the monster tire look...
04-30-2012, 04:47 PM | #4 | ||
| Re: wheel offsets and size Quote:
04-30-2012, 07:37 PM | #5 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
2.2 Pitbulls are a very wide tire. I wouldn't go any less than a 1" wheel, personally. I have them mounted on 1.2" wide Motoworx wheels and they fit nicely.
04-30-2012, 08:32 PM | #6 | |
But I think I might just do 1.9 for now And after looking at those there's no options really for width or hub size so that makes it easy to pick one .. | |
wheel offsets and size - Similar Threads | ||||
40 series wheel offsets | MaxxZilla | Tires and Wheels | 3 | 12-03-2010 11:50 AM |
understanding wheel offsets and more.... | James003 | Tires and Wheels | 0 | 04-22-2010 04:51 PM |
VP Wheel Offsets for Bullys | EXW | RC4WD Bully | 7 | 01-19-2010 05:42 PM |
which wheel offsets for vp dh procomp's | J-Money | Team Losi Comp Crawler | 8 | 10-11-2009 03:41 PM |
Advantage of Wheel Offsets? | CoolRC | Newbie General | 1 | 07-07-2009 09:53 PM |
