05-07-2012, 08:23 PM | #1 |
Newbie Join Date: Apr 2012 Location: Alma,mi
| SCX10 steering mod
Im new to the crawling world. I noticed the poor turning radius with my SCX10. I want to do the Wraith/XR10 steering mod. What parts do I need? any tips?
05-07-2012, 09:05 PM | #2 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
| Re: SCX10 steering mod
Welcome to the forum. There are some improvements to be made to the SCX steering. The XR mod is probably the best there is...here is a thread I have found helpful xr10 axleshafts on stock width axle If you search through the AX10 section there are quite a few other builds that have done this mod. Good luck |
05-07-2012, 10:00 PM | #3 |
RCC Addict Join Date: Nov 2008 Location: Santa Fe, NM
You'll need the fallowing parts for the XR Mod Standard beef toobs XR-10 universals XR-10 and or Wraith C-hubs XR-10 and or Wraith Knuckles and that's keeping the stock AX or SCX stance you can also do longer beef toobs and not have to shorten the XR universals. |
05-12-2012, 08:06 AM | #5 |
Newbie Join Date: Mar 2006 Location: hanford
So to do the xr steering mod on my scx10 all i need is axial part numbers ax80061 and ax80062 which is the c hubs and knuckles? From what i was reading ivf you dont want to do a bta steering thats all you need.
05-12-2012, 10:48 AM | #6 |
Beef tubes are not necessary. 5 minutes with a dremel or a file on the stock housing will allow the XR c hubs to slide on the AX housing.
05-12-2012, 10:48 AM | #7 |
I have read the same thing... you could always try the stock plastic ones before buying aluminum to make sure. I'm going to try it soon also, I have the stock parts I just haven't been able to swap them out yet. Post up what you find out.
05-12-2012, 12:49 PM | #8 |
Truism, beef tubes aren't necessary but are nice to have. Worthwhile mod to do in any case.
05-12-2012, 02:23 PM | #9 |
Sweet I'm gunna order those parts and try it out and let everyone know how it goes.
05-13-2012, 07:03 AM | #10 |
Quarry Creeper Join Date: Jul 2009 Location: Buffalo area
Im going to have to try this too.... CVD's and high steer knuckles didnt improve steering all that much for me. |
05-13-2012, 09:11 AM | #11 |
yeah im excited to try this mod and the parts that i listed above is only 16 bucks from towerhobbies.
05-13-2012, 07:43 PM | #12 |
Quarry Creeper Join Date: Mar 2011 Location: over there...
i wish i did this before i brought the vp 8* crap |
05-14-2012, 05:58 AM | #13 |
Rock Crawler Join Date: Mar 2011 Location: hampton
i took a cone shaped dremal stone to the inside if my stub axles, and relocated the front c hub mount screws and got a noticeable increase in steering
05-14-2012, 06:10 AM | #14 |
| Re: SCX10 steering mod |
07-26-2012, 11:17 AM | #15 |
Pebble Pounder Join Date: Dec 2011 Location: Buffalo
Could the scx10 universals be cut down to fit? Or are the xr10's uni's longer? And as far as the beef tubes go, I don't have any in my stock scx10, am I missing somethig ?
07-26-2012, 12:06 PM | #16 | |
Beef tubes are not a stock part, or made by axial either. | |
07-27-2012, 06:12 AM | #17 |
Ok cool so everything needed that way previously mention has to be purchased? The only part that will be re used is the diff?
07-27-2012, 08:34 AM | #18 | |
RCC Addict Join Date: Apr 2011 Location: San Diego
| Re: SCX10 steering mod Quote:
You are simply swapping your scx10 Chubs/knuckles/cvds for the xr10 Chubs/knuckles/cvds and reusing everything else (housing, bearings, hardwre, diff locker.) Optional pieces are the beef tubes and a felsenfest no-slop locker. Did this mod on my JK and it works awesome! | |
07-27-2012, 11:10 AM | #19 |
Thanks a lot for the quick/ detailed response. Cant wait to do the mod. The scx10 has by far the worst LimitEd steering
07-27-2012, 12:14 PM | #20 | |
You dont need to do aluminum CHUBs/Knuckles if you dont want to....much cheaper $18 vs $70+ just for those 2 parts lol. I'm using plastic to test, then when (and if) they break I'll consider upgrading. I dont wheel very hard so they may last a LONG time. You can also get delrin tubes that are pre-splined to fit the xr-10/wraith Chubs. | |
SCX10 steering mod - Similar Threads | ||||
Xirtic + JP High Clearance Steering Mod on Mod | JeffK11 | RC4WD Bully | 1 | 02-01-2012 09:55 AM |
R1 STEERING MOD maybe? | cul8tr | G-Made Crawlers | 3 | 02-06-2011 01:40 PM |
SCX10 steering servo mod. | towtruckmikey | 1.9 Scale Rigs | 3 | 09-19-2009 04:47 PM |
Front Dig Mod,steering mod & pushbar | TheButcher69 | General Crawlers | 1 | 11-06-2006 06:32 PM |
where is the steering mod | 12flex | General Crawlers | 1 | 05-08-2006 09:34 PM |
