05-12-2012, 07:50 AM | #1 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
| One wheel spins freely
What could be the issue? |
05-12-2012, 07:53 AM | #2 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
Broken differential gears, broken diff locker, broken axle shaft... Grab a few tools and tear into it. Take pics and post the results. |
05-12-2012, 08:11 AM | #3 |
| Re: One wheel spins freely
Its the front wheels so broken diff locker will not be an issue?
05-12-2012, 08:23 AM | #4 |
RCC Addict Join Date: May 2008 Location: Green Bay
Front and rear axles are the same internally so yes it could be.
05-12-2012, 08:35 AM | #5 |
Pebble Pounder Join Date: Feb 2009 Location: wilkeson
Have you even tore it apart yet? If your not running the spool in the front then that's the problem. Last edited by axman; 05-12-2012 at 08:38 AM. |
05-12-2012, 08:52 AM | #6 |
Newbie Join Date: Mar 2006 Location: hanford
It could be the little pin that goes through the axle right at the wheel. Take your wheel off and check the pin and the 12mm adapter to the wheel. Maybe something broke externally.
05-12-2012, 10:52 AM | #7 |
05-12-2012, 11:20 AM | #8 | |
| Re: One wheel spins freely Quote:
BINGO!! I was at the trail and forgot my hex key so I wasn't able to take out the wheels to check. I lost the pin (wheels are pinmount). | |
05-13-2012, 08:33 AM | #9 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
Nice...gotta love it when it's an easy fix. Good call stickboy |
05-13-2012, 08:56 AM | #10 |
thanks I always seem to have troubles with those things falling out and losing them. i cut the motor shaft off an old mini-t motor to get me through the weekend one time. |
One wheel spins freely - Similar Threads | ||||
Berg V2 axle rear wheel spins slower | i-5 | EnRoute Berg | 9 | 06-09-2011 05:41 AM |
should these axles be spinning freely? (freewheeling) | 53 willys | Axial XR10 | 14 | 10-31-2010 08:47 AM |
How freely should the Spur Gear spin? | Steve at Danfor | Axial SCX-10 | 11 | 04-10-2009 01:29 PM |
Need help motor only spins in reverse | goslo | Electronics | 3 | 07-17-2007 05:28 PM |
Got some spins for the Lift..... | Mad Hatter | 1.9 Scale Rigs | 12 | 11-02-2006 04:19 AM |
