07-12-2012, 10:27 PM | #41 | |
RCC Addict Join Date: Apr 2010 Location: Outdoors
| Re: How to do the narrow XR10 mod to Axial axles Quote:
07-28-2012, 06:26 PM | #42 |
Quarry Creeper Join Date: Jan 2009 Location: atlanta
How does this compare to high steer knuckles and Axial cvds.I am trying to stay in Class 1 rules,the extra 1/2" may make it outside the body and wheel well rules.Thanks
07-28-2012, 07:25 PM | #43 |
RCC Addict Join Date: Apr 2011 Location: San Diego
Well I'm not entirely sure. My hilux has a 11.4" wheelbase and the hi steer knuckles and cvds. It has the same turning radius as my JK with 13.1" wheelbase. You figure the shorter wheelbase would help but the highsteer knuckles didn't seem to improve my steering too much more compared to the stock knuckles. Both have a 5ft steering circle. Only way to make it more narrow would be with offset wheels or shave down the axle width. Or add fenders. |
12-26-2012, 12:59 PM | #44 | ||
and checking your sig link build. Last edited by Natedog; 12-26-2012 at 01:58 PM. | ||
01-19-2013, 09:07 PM | #45 |
| Re: How to do the narrow XR10 mod to Axial axles Left Stock XR10 Universal, Middle is modded Xr10 Universal, Right is MIP CVD for scx10. Updated some more pics since I just did this mod again! =) Last edited by Shinjari; 01-19-2013 at 10:01 PM. |
01-20-2013, 12:11 AM | #46 |
Oh boy oh boy.. I have stock chubs an knuckles laying around! An a couple sets of uni's! Next mod coming up.. Thanks for the great write up! |
01-20-2013, 09:58 AM | #47 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Good info I may have to do some testing . I use the 8 degree vanquish stuff and my tires rub on the shocks at full lock. Thanks guys.
01-20-2013, 10:55 AM | #48 |
Yeah my tires will rub the shocks at full lock, so I had to mess with the EPA's to prevent that but even though that happens you gain a stupid amount of steering over stock =)
01-21-2013, 09:10 AM | #49 |
Pebble Pounder Join Date: Dec 2011 Location: Buffalo
So if you don't have a locker do you need to cut down the axles? And in the first pic posted, you taking off the round boss? But in the second pic aren't you needing that piece for the c hubs to attach to? I'm a bit confused. Im running a stock scx10 axle, i dont have beef tubes, how wide will my axle be with this mod? im confused on where the 1/2" bigger is coming from. This is what I have on order. - xr10 c hubs - xr10 knuckles - xr10 uni's( haven't ordered these yet) |
01-21-2013, 11:07 AM | #50 | |
You need to remove the bolt retaining section on the 'front' and 'rear' to like in this picture. This is the side profile. You cut the bolt section completely off and file the top and bottom tabs to be sharp and not square. This is how the CHUBs will attach to the axle You do not need to shave anything. The 1/2" is on each end and its based on the CHUBs and Knuckles, they are slightly wider than the scx10 chubs/knuckles. Beef tubes are not needed but definitely help stiffen things. If you dont have a no-slop lock you will just need to be better at making the flat spots in the axles to fit properly in the stock locker. The benefit of the no-slop is it is forgiving in how precise you file them down. Last edited by Shinjari; 01-21-2013 at 06:42 PM. | |
01-21-2013, 12:14 PM | #51 |
Ok. Thanks for that. Once I get it apart I think I'll understand what I need to do. I just got a little confused by the pics.
01-21-2013, 04:04 PM | #52 | |
Here are a few things that might help: You WILL have to cut the universals and file flat spots on them. The XR universals are longer than the stock dog bones w/ axle cups from the spot where they run on the axle housing/bearing to the end of the hub. Approx. 7.53 mm per side or 15.06mm total ( which is .590 inches). This is the half inch in increased axle width. Here is a pic of the modified axle housing. The "boss" needs to be removed so the XR/Wraith hub will slide over it. The areas that you will cut/file into pointed ridges are the two flat spots (top and bottom) that are created when the two halves of the housing are put together. The inside of the XR/Wraith hubs are splined and this will allow you to clock the hubs. Another thing that might help is to file the end of the universal flat before cutting it to length. This way you can use the factory flat as a guide to keep the flats parallel and consistant. Just for FYI...this is a shot of the stock Axial locker next to a HR locker. They are within a few mm's of being the same width. | |
01-21-2013, 11:07 PM | #53 |
Shinjari and MrJoshua, thanks for the updates with detailed pics and instructions! |
01-22-2013, 06:11 AM | #54 | |
That helps a ton. Thanks. Quote:
05-10-2013, 01:23 AM | #55 |
Newbie Join Date: Jun 2009 Location: The land of OZ
How did i go wrong?? I got the axial parts ax30760 and ax30762 plus xr10 axles. Installed and the front left wheel will be leaning in at about 15 degrees. What is wrong with the way i have done this???? For some reason i am unable to post attachments.. I have a photo at the ready. Last edited by amec; 05-10-2013 at 01:25 AM. Reason: trying to add a photo |
05-10-2013, 01:55 AM | #56 | |
RCCrawler.com Bulletin Board - FAQ: Board FAQ | |
05-10-2013, 06:04 AM | #57 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
Sounds like you have put the c hub on upside down.
05-10-2013, 01:15 PM | #58 |
| Re: How to do the narrow XR10 mod to Axial axles |
05-10-2013, 04:57 PM | #59 |
Nope, not upside down. Checked that first. The longer arm goes on the bottom, both sides. I think i received 2 right knuckles. |
05-10-2013, 07:44 PM | #60 | |
Rock Crawler Join Date: May 2011 Location: SoCal
For pictures are you using an image hoster? Just copy and paste the link that starts with [IMG]. I use imgur. It's free, and requires no login or registration. | |
How to do the narrow XR10 mod to Axial axles - Similar Threads | ||||
XR10 Mod for AX10 Axles Parts List | WooPigSooie | Axial AX-10 Scorpion | 96 | 01-30-2016 12:23 PM |
how to narrow axial axles. | Brian in MI | 1.9 Scale Rigs | 5 | 04-14-2009 04:12 PM |
anyone ever narrow axial axles? | kuatto | Newbie General | 1 | 03-31-2008 09:38 PM |
