02-13-2014, 02:32 PM | #81 | |
Rock Crawler Join Date: Feb 2010 Location: Paw Paw, MI
| Re: How to do the narrow XR10 mod to Axial axles Quote:
Red lines show the angle of the tires with the curved arms on the XR/Wraith knuckles (like you have it now), blue lines show the angle of the tires with the zero ackerman steering arms installed Blue lines are using these here I did this mod a long time ago and still think it is one of the best mods you can do to these things. Bunch of info and pictures from when I did it here Last edited by Ramination; 02-13-2014 at 02:37 PM. | |
02-28-2014, 09:29 PM | #82 |
Newbie Join Date: Sep 2011 Location: Australia
Ok guys, I've seen it somewhere and after going thru this thread about 3 times now, can't find it either. When doing this shortened mod using the VP wraith C-hubs and knuckles, how much exactly am I cutting off the end of the VP VVD front shafts?? I'm just waiting for my RC Bros brass splined burly tubes to come and then I'm into it.
03-01-2014, 08:45 PM | #83 |
Newbie Join Date: Jun 2009 Location: The land of OZ
When I did mine I used the xr10 uni's and i think it was about 1cm approximately. The way I did mine was to have the diff case in half with the chub's, knuckles, cvd's installed. Then measure the length required so the cvd axle part got to about 3 mm from the centre of the diff locker. This gave enough room to ensure clearance from each cvd in the middle. Take your time when filing down the new flat to go into the locker, the first one i did I went a bit too far and created some slop. |
03-01-2014, 08:49 PM | #84 | |
03-02-2014, 09:47 PM | #85 |
Ok, so having a go at filing down the first VP shaft and noticed it has a slight shoulder and the original diameter of the end part with the flat is marginally thinner than the rest of the shaft. Do I have to reduce this shaft diameter where the new flat spots are filed or will it still fit inside the locker(ome axial locker)?? I wanted to try and work out what I'm doing before I actually cut the shaft to length. Heres a pic of what I've done so far... keeping in mind I've not gone to an exact same flat as original just yet... want to try and get it a snug fit to reduce the chance of slop in the locker. |
03-02-2014, 09:50 PM | #86 |
Just test fit it into the locker and see if its good.
03-03-2014, 08:14 AM | #87 |
Quarry Creeper Join Date: Mar 2006 Location: Pewee Valley, Kentucky
What bent steering links work well with this mod?
03-03-2014, 10:12 PM | #88 |
Dont know if there is an off the shelf link made for this mod. I used a 110mm link, original steering link i think with a 33mm link added. Then bent to clear the pumpkin. I tried 4mm threaded rod but it bends out of shape when the steering is bound up and the Hitec 7955 forces the issue.... |
03-03-2014, 10:22 PM | #89 |
If you sleeve the rod it becomes more durable. Who wants off the shelf parts? |
03-03-2014, 10:35 PM | #90 | |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
03-04-2014, 02:37 AM | #91 | |
03-04-2014, 09:37 PM | #92 |
| Re: How to do the narrow XR10 mod to Axial axles |
03-07-2014, 03:36 PM | #93 | |
Yes. | |
03-12-2014, 03:51 PM | #94 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
How would I go about eliminating the 1/2" of extra front track width? I'm very close to the front inner tires extending past the outside of the body on my 1.9 scaler. I have all the parts to do this MOD, but want to make sure I'll tech out in an inspection? Thanks for any help . |
03-19-2014, 07:40 PM | #95 |
Rock Stacker Join Date: Jan 2014 Location: Charlotte
I completed this mod today. Is it normal for it to "wheel hop" a little at full steering lock? I tested it out in my living room tonight and it turns awesome, but it has a hop almost like something is binding. Do the unis need breaking in? or is it the carpet making it do this? I ran it on tile and wood deck and it helped a little but still "hopped" at full lock. Any advice is appreciated!!
03-19-2014, 08:16 PM | #96 |
I wouldn't call it "normal" but yes it does happen when at full lock and turning past the usable angle of the universal. Might wanna back your epa down a bit or only use full lock when needed at low throttle.
03-19-2014, 08:33 PM | #97 | |
RCC Addict Join Date: Apr 2011 Location: San Diego
Yeah you're basically going past the unable amount of steering on the universals without modifying them (Dlux in the vendors mods them to be smooth up to 70*). Make some steering stops or set your EPAs. Very similar to how when you max out steering on the stock dogbones, its hops. Quote:
Only thing I can think of would be custom narrowed wraith housings. Can't really narrow the scx10 housing any more to get that 1/2" back. Unless you can find some better offset wheels. that'd help too | |
03-20-2014, 03:36 PM | #98 |
Thanks for the replies. I kind of figured it was the unis binding, because the xr mod has sooo much throw! I will just drive around it for now.. Im headed over to check out the dlux unis now. |
06-05-2014, 10:44 AM | #99 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
Thread tag for wanting to take on this mod as well
06-15-2014, 08:46 AM | #100 |
Quarry Creeper Join Date: Dec 2008 Location: Missouri
Has anyone done this mod with cms? I have cms and have ordered the parts to do this and was a little concerned.
How to do the narrow XR10 mod to Axial axles - Similar Threads | ||||
XR10 Mod for AX10 Axles Parts List | WooPigSooie | Axial AX-10 Scorpion | 96 | 01-30-2016 12:23 PM |
how to narrow axial axles. | Brian in MI | 1.9 Scale Rigs | 5 | 04-14-2009 04:12 PM |
anyone ever narrow axial axles? | kuatto | Newbie General | 1 | 03-31-2008 09:38 PM |
