02-11-2016, 04:10 AM | #141 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
| Re: How to do the narrow XR10 mod to Axial axles They do exist. Now we wait. http://www.rccaraction.com/blog/2016...and-d60-axles/ http://www.rpphobby.com/product_p/ssd00086.htm I'm actually in the process of fitting two long Wraith Universals to my scx10 axles. Dlux Fab sells each side separately here. https://dluxfab.ecwid.com/#!/Wraith-...tegory=6232189 I'm cutting them to length then TIG welding additional thickness on the ends so I can machine them to spec in my lathe. I know it's complicated and not for everyone but I thought I would mention it. As it's about the only current option if you want true universals and not Cv's. Last edited by Mnster; 02-11-2016 at 04:16 AM. |
04-19-2016, 08:36 AM | #142 |
I know you guys have dried up the axles for a bit. Not sure when Axials will be back but here is a great, stronger option for XR shafts FBA axle shafts - XR length – Dlux |
04-23-2016, 05:45 PM | #143 | |
| Re: How to do the narrow XR10 mod to Axial axles Quote:
Unless the chub does not press as far on, the chub won't change the measurement. 8* stuff and non 8* stuff would use the same length inner shaft. I have a set of scx inner shafts here and get the same results as above. Scx looks to be roughly 1/8" shorter than the shafts you guys are making. Are you guys just making them longer than standard for full engagement? I am just thinking I could make FBA shafts in scx length and cover both cars? Last edited by Erik D_lux; 04-23-2016 at 08:36 PM. | |
04-23-2016, 05:51 PM | #144 |
| Re: How to do the narrow XR10 mod to Axial axles |
04-23-2016, 08:40 PM | #145 |
| Re: How to do the narrow XR10 mod to Axial axles I am asking because I like to know as much about a product as possible before making them so I can make the best product I can, especially before dropping $1000's of dollars on them just to find out I made a boo boo. I dont know what the answer is going to be. If you have the info, I would appreciate it. Sorry if I am missing something simple. If I look at the above pictures and other pictures in this thread of the modded XR shafts, it DOES NOT look like the stock SCX shaft will work (at least that well). Maybe you could get away with approx 1/8" of engagement but I wont be making a product that is designed with that little of engagement. |
04-23-2016, 09:02 PM | #146 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
I know the first time I did an xr mod I was afraid because it seemed like I had to cut off more than what the write ups were saying. Otherwise the shafts would bottom out, so maybe we are just running them long..? Sent from the can using Tapatalk |
04-24-2016, 04:37 PM | #147 |
Great feedback. Thanks!
04-25-2016, 08:38 AM | #148 | |
I also didn't mean sound like attitude, I meant that awesome your looking into having inner shafts. I'm actually about start this mod myself. | |
11-15-2016, 04:10 AM | #149 |
Newbie Join Date: Nov 2016 Location: France
Hi everyone from France ! I' didn't see the new members presentation suject as your forum is a huge one ! So, sorry to make a quick my prensentation here. And sorry for my appromate english writing and comprehension. :-) By the way I'm the administrator of French Scale and Crawler forum and tutorials for beginners : www.rc-decouverte.com If you wonder what we do in France, you should find us on our youtube channel : https://www.youtube.com/c/RcDecouverte So, I came on RC Crawler as to find some help and tips for the steering modifications of my stock scx10. After reading this very interresting subject I have the following questions : 1) Can you tell me external diameter of the tube in the axle housing on the following picture : 2) In this subject, someone gave the URL of the SSD HD CVD Axles for SCX10 / D60 Axle (part number SSD00086) : SSD HD CVD Axles for SCX10 / D60 Axle This CVD axle could avoid me cutting and drilling XR10 cvd : less work for me. Will this cvd axle fit on XR10 C-Hub + XR10 Knuckle + Stock scx10 axle housing ? I would like to know if the SSD00086 cvd axle lenght will be too short as it's done for Scx10 stock parts, not for XR10 C-Hubs and Knuckles ? Thanks in advance. |
How to do the narrow XR10 mod to Axial axles - Similar Threads | ||||
XR10 Mod for AX10 Axles Parts List | WooPigSooie | Axial AX-10 Scorpion | 96 | 01-30-2016 12:23 PM |
how to narrow axial axles. | Brian in MI | 1.9 Scale Rigs | 5 | 04-14-2009 04:12 PM |
anyone ever narrow axial axles? | kuatto | Newbie General | 1 | 03-31-2008 09:38 PM |
