06-27-2012, 05:32 PM | #1 |
Newbie Join Date: Jun 2012 Location: central
| to trim or not to trim?
I actually got a perfect paint job not a scratch or run on it but I can't use it without trimming with 1.9s nvr mind 2.2s I hate to cut into it cause it'll look like a third grade art project if I do lol |
06-27-2012, 05:44 PM | #2 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
Maybe adjust the link length so your tires are dead on centered in the wheel wells. Then add bump stops on the exterior shock shaft just long enough so the tire goes and just misses kissing the body at full stuffing. You will lose a tad articulation but hey, no body trimming.
06-27-2012, 06:12 PM | #3 |
Rock Stacker Join Date: Jun 2012 Location: San diego
| Re: to trim or not to trim?
U cant raise the body up alittle? I like that blue u used! Great choice
06-27-2012, 06:25 PM | #4 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
Good job on the paint. Looks like it just needs the wheelbase moved around.
06-27-2012, 06:35 PM | #5 | |
Newbie Join Date: May 2012 Location: Chico
| Re: to trim or not to trim? Quote:
Seriously though, looks like the wheelbase is off a little bit. Shorten the wheelbase and you might not need to trim? | |
06-27-2012, 06:55 PM | #6 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
| Re: to trim or not to trim? x2 , looks like if you pull your wheels in just a little, you would be able to make it work ok.. killer paint by the way !!
06-27-2012, 07:08 PM | #7 |
Pebble Pounder Join Date: Jun 2010 Location: bowling green
I'm running the 80's body with 2.2's I just raised my body all the way up and trimmed a bit it still rubs a tad under full articulation but not to bad |
06-28-2012, 02:58 AM | #8 |
Ya I tried to figure the right wheelbase but I got 5 bodies I need to buy bout 4 more scx10s so I can get it right wit all dem lol
06-28-2012, 06:48 AM | #9 |
Quarry Creeper Join Date: Sep 2010 Location: Perth Australia
Trim it mate, its only a body hey, after you use it a few time it will get scratched anyway
06-28-2012, 02:08 PM | #10 |
Newbie Join Date: Apr 2011 Location: somewhere??
I say trim, make it do what the chassis is made for, crawling. Unless it's going to sit on a shelf and collect dust from your house and not from outside. Just my opinion. Edit: by the way your bumper is painted blue. Last edited by TheOgre; 06-28-2012 at 02:12 PM. |
06-28-2012, 03:20 PM | #11 |
Quarry Creeper Join Date: Feb 2012 Location: Texas - just outside of Austin
Fix the wheelbase...takes 15min with a dremel and a little bit of experimenting.
06-28-2012, 03:29 PM | #12 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
Tip if you decide to trim. Take a sharpie and color in where you would want to trim back. Then you can stand back and get an idea of what your wheelwells and overall look will be before trimming it. You can remove sharpie with just some rubbing alcohol. If your colored in "trim" areas do not look good, keep experimenting till you get a look you like. A more curved wheelwell may sound like what you want but when you see it done, it doesn't look right on the vehicle. This may help before you go and cut, cause once it is cut, there is no going back. Good luck |
06-28-2012, 05:17 PM | #13 |
you could look into getting a set of dingo fender flares, then cut and trim, and put the flares on..they look good imo on all kinds of bodies
06-28-2012, 09:59 PM | #14 |
Flares look pretty Cool I'm gonna cut it but I butchered my xj so I'm takin it slow I'm gonna whip up some new links first so I got a better idea wat I'm dealing with |
07-06-2012, 04:33 AM | #15 |
Little trimming on links and body |
to trim or not to trim? - Similar Threads | ||||
windsheild trim | flynfred | 1.9 Scale Rigs | 3 | 03-01-2011 12:01 PM |
To trim or not to trim | bro_die | Axial AX-10 Scorpion | 18 | 12-30-2010 07:59 AM |
tq 2.4 4th channel trim? | luke-o | Electronics | 1 | 03-09-2010 03:38 AM |
i cant get the trim set | bigdog5332 | Electronics | 1 | 03-20-2008 07:25 PM |
fender trim | nodnarb81 | Paint and Body | 2 | 02-17-2007 09:12 PM |
