07-09-2012, 08:17 PM | #1 |
Newbie Join Date: Oct 2011 Location: Akron
| Semi-Stock Xj Build
So i've been wanting to build an Xj scaler for a while, and im just getting to it now. Currently in the process of rebuilding my rig from its neglected state. Just made all new links for it and am in the works of making a panhard bar for a cms setup. Trying to fab mostly everything myself due to being on a tight budget. Rear shocks are from my Jammin scrt-10, a little stiff but i think i want this to be a tow rig in the future so that should be beneficial. Upper links have also been shortened and relocated farther up the frame rails. Parts soon to be ordered: -Pro-Line Xj body -Spider gears and diff cup for front axle (going for the stock open diff in front performance) -Servo (someone point me in the right direction here, need something very inexpensive but with decent power) -Wheel weights-going with lead stick-on balancing weights -Junfac driveshafts Well, onto the pictures! These show the beginning of my panhard mount on the axle, and my old extremely hacked dingo truggy body. [IMG] By bsweitzer99 at 2012-07-09[/IMG] [IMG] By bsweitzer99 at 2012-07-09[/IMG] [IMG] By bsweitzer99 at 2012-07-09[/IMG] [IMG] By bsweitzer99 at 2012-07-09[/IMG] [IMG] By bsweitzer99 at 2012-07-09[/IMG] [IMG] By bsweitzer99 at 2012-07-09[/IMG] [IMG] By bsweitzer99 at 2012-07-09[/IMG] [IMG] By bsweitzer99 at 2012-07-09[/IMG] Last edited by Speedrc91; 07-09-2012 at 08:51 PM. |
07-09-2012, 08:38 PM | #2 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: Semi-Stock Xj Build
holy huge pics batman!!!!!!!!!!!! resize them a bit smaller for us!!!!!!!!!!!!!!! |
07-09-2012, 08:45 PM | #3 |
On my screen they show up normal..hmm ill try and resize them
07-10-2012, 05:44 AM | #4 |
Rock Stacker Join Date: Jun 2012 Location: Cleveland
On a 1680 x 1050 resolution, you can see 1/3 of the picture on the screen.
07-10-2012, 03:39 PM | #5 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: Semi-Stock Xj Build For the servo, I always have good luck with the Hitec 645MG, it;s decent and not expensive. For the driveshafts, stay away from junkfac....I bought a set for my Tamiya CR01, on the 1st run the turck started to wobble all over the place, I found that a little bit of sand was binding up the joints. I took them apart to find them galled up, I polished everything up and headed back out. 1 pack, everything ok, 2nd pack, shafts started to bin up again. I took them off and used something different. |
07-10-2012, 06:05 PM | #6 |
Newbie Join Date: Dec 2008 Location: valley
ill second the Hitec 645mg, i had one laying around that i threw on my build that has a 2007 sticker on it, haha i have one dated 2010 for backup.
07-10-2012, 09:33 PM | #7 |
Next time around ill make sure and size them down a bit. And arent the junfacs the same idea as MIP's?
07-11-2012, 09:33 AM | #8 |
Quarry Creeper Join Date: Dec 2010 Location: Lodi
Yea the JunFac is the same general idea as the MIP but the MIP shafts are WAY BETTER!! I've been using the same MIP's for 3 years (including about 25 scaler comps) and never had a single issue. I've seen guys with brand new JunFac shafts having issues on the trail. It's worth the difference in price to buy the MIP.
07-12-2012, 09:53 PM | #9 |
Well hopefully tomorrow afternoon the body and rest of the parts will be ordered!
07-18-2012, 08:24 PM | #10 |
Body and differential gears odered, along with junfac driveshafts and steel outputs!
Semi-Stock Xj Build - Similar Threads | ||||
we'll this is my first semi scale build | ped453 | 1.9 Scale Rigs | 5 | 10-28-2009 03:31 PM |
my 1/6 semi stock crawler | cartronicshn | General Crawlers | 2 | 05-26-2006 05:51 AM |
