Thread: RC4WD TracGear poor fit??
Old 08-15-2012, 09:49 PM   #1
Default RC4WD TracGear poor fit??
I just bought two of the RC4WD Trac Gears for my SCX10. When I installed them, the axle case halves did not fit together very well. I took them apart again, checked to make sure the bearings where seated properly, and the gear teeth where properly meshed. I reassembled the axle, mounted it in the truck (yes the gears were well greased), and took the truck out to test it. The axle was VERY bound up. It's so tight, it preloads the suspension before it moves. The truck moves, but it really does not want to.
Does anyone have experience with this gear set? Also, RC4WD, in the description, said the gears may be noisy at first, but will quiet down over time.
Thanks in advance guys.
GRTrailRider is offline   Reply With Quote
Old 08-15-2012, 10:39 PM   #2
Default Re: RC4WD TracGear poor fit??
Sounds like the gears are rubbing the diff housing. I know nothing about this, but just in case, check the diff housing, and look where the spur sits, maybe it left a mark?
mitchr97 is offline   Reply With Quote
Old 08-15-2012, 10:43 PM   #3
I looked at the rc4wd tracker gear spool locker thread in the related threads on the bottom, and it sounds like that happens with every one, and it just needs some "break in time"
Old 08-15-2012, 10:44 PM   #4
ScaleFreak93's Avatar
Are you absolutely sure that your mesh between the ring and pinion isn't too tight? I know they are a bit tighter when new but they shouldn't be causing so much resistance as to not want to move and preload suspension.
ScaleFreak93 is offline   Reply With Quote
Old 08-16-2012, 08:55 PM   #5
I'll take it apart tomorrow if I get a chance. When I was assembling it, it felt as if the bearings (which fit before) did not want to 'pop' into place. I'll check to see if it is rubbing, and post whatever else I find out. I read the other thread, as well. Hopefully the gears just need some 'break in'.
Old 08-20-2012, 10:19 AM   #6
It seems there is no room for the ring gear in the axle. I had to loosen the case screws up to the point that they are just snug, now the rear end moves as it should. The RC4WD ring gear is a bit bigger than stock.
Old 08-20-2012, 11:16 AM   #7
Are there shims in your axle?
Lukescb7 is offline   Reply With Quote
Old 08-20-2012, 06:08 PM   #8
No, the gear mesh is correct (until I tightened up the axle halves). I left them snug, as I said, and ran at the beach for about an hour today. The motor was a little hot, but that is usually the case when running in the sand.
RC4WD TracGear poor fit?? - Similar Threads
Rc4wd Wheel fit question. briang Axial Wraith 20 12-22-2011 08:08 AM
how to fit 2.2 tsl to rc4wd steel beadlocks? 350oshin Tires and Wheels 7 10-18-2011 12:06 PM
RC4WD Tracgear Spool Locker creepstreet Axial AX-10 Scorpion 7 03-30-2008 03:30 PM
poor poor bubba m0nkey98 Chit Chat 5 01-12-2007 10:08 PM
