07-20-2012, 07:58 PM | #1 |
Newbie Join Date: Jul 2011 Location: Louisiana
| CMaD's Wroncho build.
Ive seen a few of these wrocho's around in the forum and loved them so I decided to start building one my self. I flipped the trans around so I had to make some custom links to bend around the drive shafts. I am also playing around with 2 different positions on the lower links. Started off with traxxas big bore shocks but didnt like how tall they were so went with some aluminum scx10 shocks. Still playing around with it so i havent mounted up the electronics yet. Honcho chassis wraith axles mip drive shafts ax10 bent lower links(mounted outside of frame) home made upper links STRC hubs and knuckles STRC steering linkage scx10 aluminum shocks billet works .7 wheels 2.2 boggers tekin FXR Tekin 35T on 3s hitec 7955T servo castle 10amp BEC |
07-20-2012, 08:00 PM | #2 |
| Re: CMaD's Wroncho build. |
07-20-2012, 08:04 PM | #3 |
07-20-2012, 08:13 PM | #4 |
Pretty snazzy upper link bending. Truck looks mean. |
07-20-2012, 08:18 PM | #5 |
Pebble Pounder Join Date: Sep 2009 Location: Rockport, TX
Man that thing is awesome, reminds me of the 4 Wheel Drive mags showing the trucks with the 2.5 ton axles and the tractor tires headin' for the mud bog!! Nice |
07-20-2012, 08:21 PM | #6 |
the boggers are a bit tall, i prolly end up running my 2.2 swampers on it
07-20-2012, 08:37 PM | #7 |
Newbie Join Date: May 2009 Location: NOR*CAL
Make a crossmember right behind the skid plate, put some tabs on it so you can run straight upper links.
07-20-2012, 09:03 PM | #8 |
07-30-2012, 01:06 AM | #9 |
Pebble Pounder Join Date: Apr 2012 Location: Herndon
Could you use a panhard setup to ditch the oddball link(s)?
07-30-2012, 05:42 AM | #10 |
07-30-2012, 11:23 AM | #11 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
looks pretty cool man!
07-30-2012, 11:58 AM | #12 |
07-31-2012, 05:47 PM | #13 |
Rock Crawler Join Date: Aug 2010 Location: Esko
Thats exactly how i made the upper links for my Wroncho. Except I sleeved them with aluminum tubing. I didn't like the angle of the driveshaft coming out of the trans to the diffs so that's why I flipped my trans to. Its worth the trouble of building custom bent upper links to have good driveshaft angles in my book. I did mine really nice and they look like a factory part. Another thing you should think about is making your upper links longer to angle the diff input up. It takes a lot of the angle off the driveshaft. It took me a few days to get everything perfect on mine. Great job. Man, I just sold my Wroncho a couple weeks ago, and now I'm kind of regretting it. Oh well, looks like I'll have to build another one.
07-31-2012, 06:03 PM | #14 |
Pebble Pounder Join Date: May 2012 Location: Satsuma
I built my own wroncho. Now I know ever build is different but why did you mirror the tranny when with the stock tranny location the drive shaft fits right through links? On mine I put a r2 rc4wd tranny but still left it in the stock position and the drive shafts fit perfectly through the wraith links..
07-31-2012, 07:17 PM | #15 | |
| Re: CMaD's Wroncho build. Quote:
07-31-2012, 07:19 PM | #16 | |
07-31-2012, 07:21 PM | #17 |
i love this thing, its my favorite truck so far, i am now running the 2.2 irok swampers on it, they're huge! Will post pics thurs.
07-31-2012, 10:54 PM | #18 | |
Stock or R2 trans work fine with Wraith links? Also, did you use SCX10 or Wraith drive shafts? It is a cool truck! I would have never thought of it but the BWD wheels are cool too! | |
07-31-2012, 11:25 PM | #19 | |
08-01-2012, 12:14 AM | #20 |
Pebble Pounder Join Date: Aug 2011 Location: Gresham, OR
That's a pretty crazy angle on the driveshaft, does it bind?
CMaD's Wroncho build. - Similar Threads | ||||
My Wroncho... | Tmaxxed | Axial SCX-10 | 6 | 02-29-2012 10:07 PM |
West coast disrtuctions wroncho build | wcdfmt510 | Axial SCX-10 | 15 | 01-26-2012 11:00 PM |
TTC-ish Scale-ish Budget-ish Wroncho-ish Build | Meatwad | Axial SCX-10 | 77 | 01-19-2012 03:00 PM |
