07-22-2012, 01:17 PM | #1 |
Newbie Join Date: Nov 2009 Location: uk
| SCX10 Honcho & Cherokee Wheelbase
Hi all. I have an SCX10 Honcho kit, which is obviously slightly too long for the Proline Cherokee body. What links should I use to get the wheelbase of the SCX10 to line up with the body? Thanks |
07-22-2012, 03:29 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
| Re: SCX10 Honcho & Cherokee Wheelbase
Changing the rear lowers to 91mm (link size not including the ends) should get you right on. Keep the 98mm front lowers. The uppers will need to be shortened when you shorten the lowers as well. If you have the metal links it will be easy by just removing spacers on the y link. If you have plastic uppers then you will have to replace it. Might as well do a 4 link at that time. What link size you use will depend on what you do and what 3 or 4 link option you choose. But to get the wheelbase right for a Cherokee it just takes 1 set of 91mm and 1 set of 98mm lower links.
SCX10 Honcho & Cherokee Wheelbase - Similar Threads | ||||
1992 Jeep Cherokee & Honcho rocking it | Rotax125 | Videos! | 1 | 07-01-2012 04:15 AM |
Cherokee on scx10 honcho | Newbie51 | Newbie General | 8 | 07-31-2011 04:32 PM |
