07-23-2012, 06:40 PM | #1 |
Newbie Join Date: Jun 2012 Location: Australia
| AX30401 Install Help! Gear shaft sticks out further than stock
I am new to this Overdriving the front axle of my scx10 honcho, I took the front axle appart and install the AX30401 overdrive gears, i noticed that the part that connects to the drive shaft tends to move or sticks out further comapared against the stock one, & i noticed that the stock have thicker gear and shorter shaft. Is this normal and leave it sliding? or do i have to move the outer bearing inside the axle? Your input is highly apprciated. Thanks! |
07-23-2012, 08:39 PM | #2 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
| Re: AX30401 Install Help! Gear shaft sticks out further than stock
How much is it moving? I have to ask: did you follow the manual to reassemble the axle with the new gear set? Stand both of them on a flat surface, place something flat on top and measure each. Report back. Initial though is you may have left out a bearing on the inside of the axle housing. My rear underdrive pinion has some fore-aft movement, a little more than the stock one in front. Nothing I'm concerned about until I hear weird noises. |
07-23-2012, 09:31 PM | #3 | ||
| Re: AX30401 Install Help! Gear shaft sticks out further than stock Quote:
Your a champ mate! Otherwise this will just ruin my Overdrive gears and eventually break the axle further down in time. Lucky i havent put it back together and run it, obviously the previous owner left this running with one bearing only. I think i have to take them all appart and rebuild them using the mannual to ensure everything is in place. Cheers! | ||
07-23-2012, 09:40 PM | #4 |
I joined the Band! Join Date: Aug 2009 Location: Maryville, Tn
You will absolutely love the gears....less torque twist.....more steering......better climbing.......a must have on these trucks:cool:
07-24-2012, 08:15 AM | #5 |
Glad to help. I have referred to my manual more times than I can count.
AX30401 Install Help! Gear shaft sticks out further than stock - Similar Threads | ||||
Ax30401 in stock!!! | johnnyh66 | General Crawlers | 0 | 07-28-2011 10:23 PM |
