07-24-2012, 07:19 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Paulding Co.
| 4 link wiith CMS???
Anyone know of a 4 link mount that will work on the front axle, and clear the servo horn with the hand brothers cms?? Most ive seen will be too tall and contact the servo horn under articulation.
07-24-2012, 07:22 PM | #2 |
| Re: 4 link wiith CMS???
I've seen the TCS boomerang 4 link up front with a hands bro CMS setup on here before. However the links were modded and the boomerang I think was grinded down a bit...might wanna try Google images search. Let me know if you find it...I plan on doing so with my Honcho one of these days!
07-24-2012, 10:20 PM | #3 |
RCC Addict Join Date: Apr 2011 Location: San Diego
| Re: 4 link wiith CMS??? Gear Head RC 4-Link Truss for Axial AX10 or SCX10 (1) should work, it works with my custom CMS on my JK. heres a pic of it. |
07-25-2012, 06:18 PM | #4 |
Rock Stacker Join Date: Jul 2012 Location: nor cal
im in the same boat,i could never get my hb cms three link setup to work well
07-25-2012, 07:34 PM | #5 | |
| Re: 4 link wiith CMS??? Quote:
If you wanna sell your Pan hard setup lemme know! =) Last edited by Shinjari; 07-25-2012 at 07:47 PM. | |
07-25-2012, 07:39 PM | #6 |
Rock Stacker Join Date: Feb 2006 Location: Williamstown
I myself, am using the factory axial 4 link truss upfront, with the factory plate bolted to the side of the frame and have no clearance issues at all.
07-25-2012, 09:10 PM | #7 |
Quarry Creeper Join Date: Feb 2012 Location: Texas - just outside of Austin
| Re: 4 link wiith CMS??? |
07-25-2012, 09:13 PM | #8 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
You won't get proper articulation using 4 link with a CMS. You will get binding hence why every kit says REMOVE the 4th link. But who reads instruction. Not you.
07-25-2012, 09:22 PM | #9 |
Pebble Pounder Join Date: Aug 2009 Location: Fort Collins
To get full articulation from a Panhard barred axle, the 4 links need to not be triangulated, so that the panhard can control the side movement. With triangulated links they are fighting the panhard under movement, if you remove an upper link (3 linking) it takes out most of the bind. An option would be to mount the upper links further out on the axle, like directly above the lower link mounts. This is why they remove the 4th link on a CMS with a panhard link.
07-25-2012, 09:49 PM | #10 |
I have no binding at all but im not using a panhard and i don't think the op is either...
07-27-2012, 06:23 PM | #11 |
yes, if i 4 link it, the panhard will not be there, with the 4th link it is kinda pointless to keep it as the 4th link locates the axle. I am trying to extend my front axle about 1/4-1/2 forward, and it puts the whole panhard/3 link out the window for sure. the only part i want to keep is the actual servo mount.
07-28-2012, 08:55 AM | #12 |
Newbie Join Date: Mar 2012 Location: Baltimore
07-28-2012, 09:57 AM | #13 |
So I went to the LHS the other day on lunch break and they had a RTR Honcho on display. I was looking at any significant improvements in design besides the rear 4 link and slightly better electronics versus the old Honcho (RTR and kit version). I was expecting the front end to be 4 linked somehow like the Ridgecrest (I know different axles). Is there a way to use the rear AX10 style 4 plastic 4 link mount on the front axle and 4 link the front as well? Plan on keeping the servo on the axle to avoid bumpsteer. If anyone has pics that would be great! |
07-29-2012, 09:07 AM | #14 |
As far as I can remember back, I believe I had a scaler a few years back where i did have both the front and rear 4 linked with the stock honcho 4 link mounts. I believe it works with very little modification to the front axle or servo mount.
07-29-2012, 09:53 PM | #15 |
Newbie Join Date: Jul 2012 Location: San Diego
the new honcho rtr has a second 4 link truss and links in the extra parts baggy. the truss is identical to the rear 4 link truss. you'll have to make sure You use the correct set of extra links as there are also a whole set of Dingo links in there as well. you'll have to provide ur own 3mm hardware though ( to mount the 4 link truss to axle and bolt/nut that hold the links to the truss) as you get no extra hardware in he bags |
07-30-2012, 02:09 PM | #16 |
Pebble Pounder Join Date: Dec 2007 Location: CDA
I used the R2J trusses on mine with the factory plate bolted outside the frame.
4 link wiith CMS??? - Similar Threads | ||||
3 link cms question | wingnutcrawler | General Scale Talk | 14 | 04-01-2012 01:52 AM |
Who has hand bro cms/3 link? | rocksteadily | General Scale Talk | 2 | 02-03-2012 07:43 PM |
Cms/4 link? | HIGH-SIDED | Axial SCX-10 | 3 | 03-09-2011 08:22 AM |
4 link set with cms | Tortuga275 | Axial SCX-10 | 3 | 08-30-2010 04:56 PM |
