08-05-2012, 09:12 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| rebuilding a scx 10
got one off a old friend a good price or so i thought.. saw a lot of water.. needs bearing.. anyway the wb8 drive shaft pin seems to be rusted in place.. broke 2 drivers and twisted my craftsman so any ideas? before something else breaks. thanks |
08-05-2012, 09:22 PM | #2 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| Re: rebuilding a scx 10
Fast eddy has $20 bearings. oil or liquid wrench for the drive shafts ( or just put some oil in the cupler, and just move it ind circle slowly with your hand, with a paper towel around it) when you take the axles apart, clean 'em out, pack it with aqua grease, then when you put it back togather, put 3x6mm skrews in the 4link mounts to keep the water out.
08-05-2012, 09:29 PM | #3 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
For the rusted grub screw, do apply some liquid wrench/break away, etc. Then maybe try a hot soldering iron to heat it up a bit. Hopefully, you didn't round out the screw any. Best of luck +1 on a set of bearings from FastEddies. |
08-05-2012, 09:33 PM | #4 |
didnt think of that might be rounded by now. i will try it
08-05-2012, 09:55 PM | #5 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
if its rounded out. get a wrench that's just a little bit to big for the screw. put it in the freezer so it will contract. then take it out and put it right into the grub screw. wait for the wrench to warm up and expand into the screw. it creates a super tight fit for the wrench and you should be able to pull it right out. ive done it before it works
08-05-2012, 09:58 PM | #6 |
great thanks good to know |
08-06-2012, 06:30 PM | #7 |
yes they are bother rounded.. will try the freezer trick... that doesnt work ill drill it out and use a nut and bolt.
08-16-2012, 05:09 PM | #8 |
Rock Stacker Join Date: Nov 2011 Location: Ripon
Hey it's probably too late, but take a tiny drill bit and drill out the center of the screw. Take your time so you don't hit the threads. Once the hole is made, it will weaken the outer part of the bolt and it will come free. Also you can buy an easy out for a couple dollars and it will work the same way. The trick is to patient and take your time while drilling it out. |
08-27-2012, 10:38 AM | #9 |
took a while but i go it.. kinda messed up the joint but i got it done. can still use the joint
rebuilding a scx 10 - Similar Threads | ||||
Rebuilding my ax-10 | wvbigal | Axial AX-10 Scorpion | 36 | 04-07-2013 09:25 PM |
help with rebuilding pack please | It usually runs fine | Redcat Crawlers | 4 | 03-08-2011 06:58 PM |
rebuilding the merc | bigoggy | 2.2 Scale Rigs | 10 | 04-23-2010 10:48 AM |
need help rebuilding diffs | four12unner | Team Losi Comp Crawler | 15 | 03-02-2010 06:12 PM |
Rebuilding my pc. | Mikekx65 | Chit Chat | 26 | 09-30-2007 10:16 AM |
