08-14-2012, 01:19 AM | #1 |
Rock Stacker Join Date: Jul 2012 Location: nor cal
| more steering?
whats the best way to get more steering out of my honcho?I have the cv's in the ront axle and tried the axial hi steer knuckles but the steering linkage hit the frame at full compression plus the turn in angle between the two fr tires is incorrect (the outter tire turns in more)
08-14-2012, 01:59 AM | #2 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
| Re: more steering?
A guy in a group I scale with just put the high steer knuckles on his dingo and had no issues with his! It actually seemed to work pretty good! Look for wheelstoo in the Georgia forums maybe he can tell you how he set his up!
08-14-2012, 03:38 AM | #3 |
RCC Addict Join Date: Apr 2011 Location: San Diego
| How to do the narrow XR10 mod to Axial axles That's the best way to get 50* or more steering. You can also get high steer/zero ackerman knuckles cvds or the VP 8* chubs and kknuckles to get more steering than stock. Also adding over drive gears to the front or under drive to the rear or better yet do both front and rear will get you better turning. Still overall the best mod is the one posted above. I have it on one of my rigs and it improved steering significantly. |
08-14-2012, 05:14 AM | #4 |
Pebble Pounder Join Date: Dec 2010 Location: Canada
^i agree, the c-hubs combined with the knuckles, both axial aluminum will give you more steering capabilities, however you really need a radio with steering limit adjustment to reap full capabilities
08-14-2012, 06:07 AM | #5 |
Quarry Creeper Join Date: Jan 2009 Location: atlanta
| Re: more steering?
Mine will hit drag link at full compression.But I dont think that is a real problem.I added a couple mm spacer to tie rod to center wheels,than centered servo horn add adjusted epa's.All good plus got almost 3 feet tighter turn.
08-14-2012, 06:52 AM | #6 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Re: more steering?
The high clearance links will require that you make a longer tie rod. You'd rather have a little toe-out than toe-in as far as steering goes.
08-14-2012, 12:54 PM | #7 |
Pebble Pounder Join Date: Jul 2011 Location: Birmingham
| Re: more steering?
I've been wondering the same thing a while for mine. Guess I will put some time into it this weekend.
08-14-2012, 02:06 PM | #8 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: more steering? this is probably the best thing for a RTR rig. you'll NEVER be able to adjust this with a stock tx even if you do all the other mods that give you the capability to steer more.
08-14-2012, 05:19 PM | #9 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
| Re: more steering?
Just so i don't disappoint Shinjari by not chiming in....i have to say the biggest steering mod that i have made so far is 4ws (for wheel steering)! XR mod is probably the way to go though |
08-14-2012, 05:49 PM | #10 |
Newbie Join Date: Dec 2005 Location: Chesapeake
| Re: more steering?
I put Wraith C-hubs and knuckles on my Dingo. My steering increased by a lot.
08-15-2012, 12:29 PM | #11 |
| Re: more steering?
cool thanks guys.the truck is the kit and im using a dxr3 radio hitec servo holmes esc ect ive been eacing rc since the 80's im just new to the crawlers
08-15-2012, 12:43 PM | #12 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: more steering? As a builder, my SCX set up of choice is Axial high steer knuckles, Axial CVD's and Hand Bros. CMS. You don't need to worry about full compression, unless your jumping it. Here's one I've built.......you can see how much steering it has |
08-15-2012, 05:55 PM | #13 |
| Re: more steering?
thats sweet
08-15-2012, 06:11 PM | #14 | |
Quarry Creeper Join Date: Dec 2008 Location: La Costa, CA
| Re: more steering? Quote:
08-15-2012, 06:13 PM | #15 |
| Re: more steering? |
08-16-2012, 03:18 PM | #16 |
| Re: more steering?
^^ man i love that rig (departure angle kinda sucks though huh?) R2J...what color of blue is that? Are the knuckles SCX/AX or Wraith/XR? Steering looks fantastic! |
08-16-2012, 09:18 PM | #17 | |
Knuckles are Axial AX/SCX high steer. | |
08-16-2012, 09:21 PM | #18 |
| Re: more steering?
Thanks man...i was just coming back to say that i looked up your build and found it. Do you get more/better steering from the axial high steer knuckles...than say, VP's? |
08-16-2012, 11:23 PM | #19 |
Pebble Pounder Join Date: Apr 2012 Location: sa
| Re: more steering?
To be honest, i didnt see much difference from stock to VP highsteer. But the XR mod has been great for me. quite a bit more more but worth it in my opinion.
08-17-2012, 05:47 AM | #20 |
Rock Stacker Join Date: Nov 2009 Location: hamilton, oh
| Re: more steering?
can we get a pic that shows the steering linkage and the hand brothers mount
more steering? - Similar Threads | ||||
inside tyre touches steering knuckle / steering linkage | murky123 | Axial SCX-10 | 4 | 10-06-2010 04:46 PM |
Getting more steering from the Bully axles after Modding for more steering | jcboof | RC4WD Bully | 15 | 01-31-2010 10:01 PM |
Hot Racing Steering knuckles - more steering than the original plastic ones? | Tomy | Axial AX-10 Scorpion | 1 | 11-16-2008 11:26 AM |
Do You Consider 4wheel steering or 2wheel steering | pedemaster-rc | Newbie General | 8 | 01-13-2006 11:52 PM |
