08-14-2012, 04:10 PM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: Dade City
| Lugging at crawl speed
My truck lugs at slooow speed but smooths out at trailing speed . Is this normal . Mabe slipper
08-14-2012, 04:15 PM | #2 |
And when I'm actually crawling it doesn't do it just on smooth stuff
08-14-2012, 04:22 PM | #3 |
| Re: Lugging at crawl speed
What electrics system? Is it a fast jiggle or a slow glitch?
08-14-2012, 05:50 PM | #4 |
Stock . More of a slow glitch like its pulses but it sounds like the the brushes in the motor passing over the contacts Sent from my overpriced phone using gremlins Last edited by josborne024; 08-14-2012 at 05:53 PM. |
08-14-2012, 08:59 PM | #5 |
Pebble Pounder Join Date: Jul 2011 Location: Birmingham
Try resetting the esc. If that doesn't work then check all your wiring to make sure nothing is loose. After that I'm lost on electronics.
08-15-2012, 07:01 AM | #6 |
Make sure your grub screw on the pinion isn't hitting the spur gear. You can also take the pinion off and see if it happens when you put a load on the motor.
08-17-2012, 03:46 PM | #7 |
The pinion was to far away from the spur adjusted it and good to go thank u-all for the point in the right direction . It was skipping teeth under a load
Lugging at crawl speed - Similar Threads | ||||
July The 7th Coronado Crawl "Crawl of the Fortress" | Docwolf | Kansas | 88 | 07-11-2012 03:47 PM |
F350 3 speed to single speed conversion, tips/ideas needed please | neo | 1.9 Scale Rigs | 10 | 02-11-2010 02:49 PM |
single speed setup vs. speed control | traxxas junky | Electronics | 18 | 08-28-2007 11:28 PM |
