Thread: Chassis mount dual servo for steering and winch.
Old 08-14-2012, 11:31 PM   #1
Default Chassis mount dual servo for steering and winch.
I am wondering if anyone has mounted two servos to the front of the chassis one for steering and the other a winch. Does anyone make a kit for this or what it have to be built my self. If you are running this setup and don't mind post some pics.
Thanks
jeepgod is offline   Reply With Quote
Old 08-20-2012, 09:56 PM   #2
Default Re: Chassis mount dual servo for steering and winch.
127 views and no answers
Old 08-20-2012, 10:22 PM   #3
I have seen this done but nothing comes to mind off the top of my head to show you as an example. Try this section, you will be more likely to get answers there - RCCrawler General Tech - Newbie General at RCCrawler.com
701 Technique is offline   Reply With Quote
Old 08-20-2012, 11:23 PM   #4
a vendor (maybe bowtie) makes a battery tray with a mount for a servo winch.
try a search; maybe use "servo winch" as your keywords.
Here's one example I found.
brianw is offline   Reply With Quote
Old 08-21-2012, 02:54 PM   #5
I did mine simialr to Bowties, but wanted my battery up front. Obviously if you run a large battery this wont work. The delrin plate is t shaped towards the tranny. The line is routed thru some break line to fairlead.
Erin is offline   Reply With Quote
Old 08-21-2012, 03:54 PM   #6
It would be nice if Hand Bros made a mount for the other side for a servo winch.
I plan on eventually mounting a servo winch up front too, but I think I will just make a mount from a piece of aluminum L bracket. I'm guessing that should be strong enough.
Big Daddy is offline   Reply With Quote
Old 08-21-2012, 04:37 PM   #7
Just use flat stock and the extra servo mounts in kit. L metal isnt necessary.
Old 08-21-2012, 09:30 PM   #8
What thickness of flat stock is recommend for the flat stock and steel or aluminum.
Old 08-21-2012, 10:39 PM   #9
.120" 6061 aluminum or 1/8" ace hardware aluminum. 18g steel would work but not much to run threads into. Aluminum is a better choice I think.
Old 08-22-2012, 06:58 PM   #10
I've seen threads using the stock axle servo mount modified for a CMS. I'm sure that could be turned to the other side for a winch. Again try a search using CMS as your keyword.
Old 08-22-2012, 07:09 PM   #11
That's how my SCX is set-up. I thought about putting another servo plate on the other chassis rail and doing a similar setup for a servo winch. I'm still running my 3Racing winch, but if I ever blow it up, I'll try and mount the servo winch to the chassis...
grob23 is offline   Reply With Quote
Chassis mount dual servo for steering and winch. - Similar Threads
servo mount winch mount question rcjunky3 Axial Wraith 0 12-10-2011 11:28 AM
chassis mount servo/winch jbrown287 Axial Wraith 1 11-18-2011 10:54 AM
scx chassis mount steering servo madazz Axial SCX-10 10 11-09-2011 09:16 PM
Super bully dual servo mount coryjones Superclass Crawlers 6 02-26-2011 04:45 PM
Chassis Mount Servo (steering/articulation interaction) Lurker General Scale Talk 8 05-15-2007 02:14 AM
