08-16-2012, 09:21 PM | #1 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| Driveshaft Q's
I tore the driveshafts out of my AX-turned-SCX-10 tuesday and had to replace both of them. I have been running a variation of the Stampede driveshaft mod for years now and discivered that the steel Traxxas output yokes are starting to egg out, especially the ones on the trans rear output. The ones on here have been to hell and back more times than I can remember, but I'm not sure if I want to just buy replacements for the Traxxas outdrives or switch to the Wild Boar 8's or MIP CVD's.. You guys have any suggestions?
08-16-2012, 10:35 PM | #2 |
Can't go wrong with mips Build em right, they're tough and reliable. Wb8's can work well too though depending on combination of power and trigger finger.
08-16-2012, 10:45 PM | #3 |
Pebble Pounder Join Date: Nov 2010 Location: Below the snow line
I have abused my MIPs with minimal issues. But am amazed at the abuse the Traxxas shafts can take. Also they are a great "weak link" in the drivetrain.
08-16-2012, 11:38 PM | #4 |
| Re: Driveshaft Q's
Guess I should also say that the truck is running an AE2 ESC, Vejom 5000mAh 9.6v hump pack, old Trinity 21t Monster Maxx 550 motor, is geared.90/14 (IIRC), and is rolling on foamless M2 1.9" Flat Irons and undrill Axial kit beadlocks that are unweighted for now.
08-17-2012, 09:04 AM | #5 |
| Re: Driveshaft Q's
I ended up ordering the MIP's, he store manager was doing special orders when I got there and with my employee discount, the MIP's were only a couple bucks more than the WB8's.
08-17-2012, 10:50 AM | #6 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
| Re: Driveshaft Q's
I've got MIPs in my rig and WB8s in my daughter's truck, can't really go wrong with either. Just keep your trigger finger in check and either are great.
08-17-2012, 03:30 PM | #7 |
| Re: Driveshaft Q's agreed, I have the MIP's in my SCX and the WB8s in the wraith. really suprised how well the WB8s are holding up in the Wraith. and i'm not easy on either truck.
08-17-2012, 05:07 PM | #8 |
| Re: Driveshaft Q's
That's good to here, I've never been easy on this truck and I figured the stronger the better with my trigger finger.........chances are my next post after installing them is that I need to trans outputs......... The rear yoke is so bad that if it were on my 1/1 Cherokee, it would probably have blown up on my drive to work this morning, especially since I had been running late................ |
08-19-2012, 07:14 AM | #9 |
Pebble Pounder Join Date: May 2011 Location: The Wizzle, MA
| Re: Driveshaft Q's
I've ended up with MIPs on almost all my rigs. The old Axial stock plastic just plain suck. The JunFacs just never seem to stay together no matter how much threadlock you put on there. Punishers are heavy, loud, expensive, and I've managed to destroy 2 of them. The WBs are a worthwhile option if MIPs aren't available, but otherwise it's plastic VS metal. And yep, outdrives will be next. I started switching to the Axial steels, but busted one of those on my FOFF so now I'm switching over to Robinson 1 piece as I break em. |
08-19-2012, 07:54 AM | #10 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Re: Driveshaft Q's
For some I always have to throw in my $.02 on these threads. All for of my Rigs run MIP's. I won't even put a rig out in the field without MIP supporting it. |
08-19-2012, 09:14 AM | #11 |
Quarry Creeper Join Date: Dec 2011 Location: Colfax, NC
| Re: Driveshaft Q's
I would think a strong drive line is good idea. I would like to figure out the cheapest weak link to have it give than breaking the most expensive parts. Just a thought I'd throw in.
08-19-2012, 09:45 AM | #12 | ||
RCC Addict Join Date: Dec 2007 Location: (LES) Manhattan, New York
| Re: Driveshaft Q's Quote:
MIP's all the way for me as well! MIP still manufactures the center drive shafts for AX10/SCX10's but have discontinued the universal CVD's for the wheels. I guess axial's version with a ring maintaining the pin in place rather than a setscrew like MIP looks to be the more simpler & popular version. Quote:
I figure i'd keep the original plastic spur gear so if rig gets caught in a bind the first thing break would be the $5 gear. It would be the cheapest to replace and quite easy as well. | ||
08-19-2012, 07:15 PM | #13 |
Quarry Creeper Join Date: Jan 2011 Location: Waterford MI
| Re: Driveshaft Q's
MIP's or nothin! Don't even waist your money on any other drive shafts.
08-19-2012, 08:35 PM | #14 | |
I'll take a blown out $3-$5 spur gear over any of the other options any day. I know the LHS has those in stock. Been seriously considering switching over to 32p gearing and adding the slipper clutch. Just a thought, LOL. | |
08-19-2012, 11:18 PM | #15 |
| Re: Driveshaft Q's
I usually try to keep the spur gear as the "fuse" in the drivetrain on everything, I work for a hobby shop and usually try to explain to people that whole theory (on Maxx's and Revo's in particular), but not all get it. My truck was converted over to a slipper years ago, so it's good there. I still need to put straight axles on the back and should look at cv's for the front at some point too, but my 1/1 XJ really needs more TLC than this one since I need to do some work on it before winter gets here.
08-20-2012, 03:11 PM | #16 |
| Re: Driveshaft Q's
Well, the CVD's were waiting for me at when I got to work! Gonna try and build then install them after work.
08-20-2012, 08:37 PM | #17 |
| Re: Driveshaft Q's
Do these things need any lube for the slider portions? They almost seem to slide like they're teflon coated.
08-20-2012, 09:47 PM | #18 |
| Re: Driveshaft Q's |
08-24-2012, 10:07 PM | #19 |
| Re: Driveshaft Q's
Got it put together and it seems to work good for what little driving I've done with it and here's a pic of that bad Traxxas output yoke....happy the one on my 1/1 XJ isn't like this! |
Driveshaft Q's - Similar Threads | ||||
A few Q's | rapttor | Losi Micro-Rock Crawler | 11 | 08-02-2011 02:41 PM |
1.55 q's | blakeski | General Scale Talk | 2 | 09-05-2010 12:02 PM |
just a few Q's | tdodm | Axial AX-10 Scorpion | 0 | 05-13-2008 06:54 PM |
a few Q's | NoobCrawler | Newbie General | 2 | 12-15-2007 10:58 PM |
new here with a few Q's | gasshead | Newbie General | 7 | 08-04-2006 10:48 PM |
