Thread: Dual Dingo build thread-My first build thread
Old 08-23-2012, 09:18 AM   #21
Default Re: Dual Dingos build thread. First build thread!
Originally Posted by 96speedZ28 View Post
How come there are no pictures of the whole rig with the body on?
Since I'm do'n a build thread and I figured since I did the body last, I would work my way to it. I could post one if you like.
juswin24 is offline   Reply With Quote
Old 08-23-2012, 09:32 AM   #22
Originally Posted by juswin24 View Post
Cause I'm do'n a build thread and I figured since I did the body last, I would work my to it. I could post one if you like.
Oh I gotcha. I was just curious why you hadn't posted one yet and kinda wanted to see it, but I can wait.
96speedZ28 is offline   Reply With Quote
Old 08-23-2012, 03:49 PM   #23
I mentioned earlier that I left the front 3 linked. I saw posts on here about needing a 7 mm spacer to change driveline angle. When I added it I found the servo hit the fame braces. Has any had this happen? It also changed the geometry of the steering. My aluminum chubs are clock able, but that didn't help. Steering looked like it was digging in. I do plan on 4 linking with the parts from the kit and I'm wondering if the same will happen.
Old 08-23-2012, 08:44 PM   #24
I've add some pics that are on page one. Couple of how I mounted the battery trays and a couple on the electronics. I think that covers this build. I didnt take pics of the painting process. Here is some finished pics of my "DINGO PIRATES"
Old 08-23-2012, 09:08 PM   #25
Lookin good man but I thought you said this was a dual dingo build?
mitchr97 is offline   Reply With Quote
Old 08-23-2012, 09:19 PM   #26
It is. I'll start posting pics tomorrow. Second build I'm customizing some. Thanks for looking! I'll get a lot of it up this weekend.
Old 08-24-2012, 05:32 AM   #27
THIS IS BUILD TWO.
Due the the lack of funds didn't install aluminum Chubs and knuckles. Will do later. I needed to find easier power connectors because the old style Deans plugs were hard for me get apart. I researched and found these Anderson Powerpole & SB Multipole Series Sets: Bags of housings and contacts in different sizes. Seem to be popular with RC Helicopter pilots. Best price I found was eBay. I'm using the 30 amp connector.i want to conceal wiring so I bought some 1/4" split wire loom to conceal them. I did want to mention, the Anderson power poles can be assembled in different configuration. The motor connectors were assembled so they will connect to the batteries.
Old 08-24-2012, 07:52 AM   #28
Lookin good man
Old 08-24-2012, 01:13 PM   #29
Lookin good man
Thanks. It's fun getting into the small details. Plus I just like building these things. All of my RC's have been kits.
Old 08-24-2012, 04:48 PM   #30
I haven't finished the ESC and receiver box yet. But I did start the fender wells or wheel wells. I saw this here Dingo Body needs.... something.....??? and I really inspired me to try and make my own. I found this video on working with Styrene YouTube - Tutorial: The Basics of Working With Styrene. I found this very helpful.
Old 08-24-2012, 04:58 PM   #31
When building these I didn't have fenders flares on. Tire clearance looked good and I new they were high enough for the flares to cover the up. What I forgot was the backing to the fender flares were almost 1/4" thick. I spaced the flares from the body 1/8" so they wouldn't rub. So I was off 1/8" on the wells and they weren't high enough to clear the flare backing. You can see in the pics I had to trim 1/8" off. I had these all glued and mounted. Styrene is so easy to work with. Marked off the 1/8", scored, snipped the corners and snapped it off with pliers.
Old 08-24-2012, 09:27 PM   #32
No one has had this problem?
Old 08-24-2012, 10:09 PM   #33
I havent man. But 3 letters: cms love them.
Old 08-25-2012, 08:27 AM   #34
I have been looking at those. I might try it out on one of the Dingos. Won't be a problem since I am not running my batteries up front.
Old 08-25-2012, 08:35 AM   #35
Some more pics of the wheel wells.
Old 08-25-2012, 09:04 AM   #36
I found the body mount design I'm using is off in the front. They have the front of the body about a 1/4" to low. I first noticed the body was not level with Rock rails. You can see this in the pic sort of. It's noticeable looking at the wheels and fender flares. By rasing the mounts up in the front might also let me raise the front bumper like I found in the Hints, tips and tricks section.
Old 08-25-2012, 09:48 AM   #37
In this picture you can see I added a couple hex nuts to raise the body post up about 1/4" to level out body. When I make the new mounting plate I might have room to raise front bumper.
Old 08-25-2012, 09:57 AM   #38
cool man! I always suggest to raise the bumper. it hits the rocks less, and it looks better
Old 08-25-2012, 09:57 AM   #39
Something I have not decided on, is the color of the next Dingo. I did paint the red Dingo on the outside of the body. I bought Bright Yellow but I'm not sure yet. I might paint the inside of #2 and do two tone with black. What do you guys think or recommend?
Old 08-25-2012, 10:30 AM   #40
I went to XT60 plugs because of some of the same hand issues you mentioned. Traxxas plugs were pretty okay on my old AX10 also. I had the same issue with spacing my front three link. Ended up with worn servo cables on two seperate servos. I installed a CMS and feel much better about it now.
Nvghostrider is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/398956-dual-dingo-build-thread-my-first-build-thread.html
Posted By For Type Date
I don't want to grow-up, 'caus if I did... DINGO Build - RC Rock Crawlers & Scalers @ URC Forums This thread Refback 03-06-2013 09:58 AM
Dual Dingo build thread-My first build thread - Similar Threads
Dual dually project thread... truckerbuddy2 1.9 Scale Rigs 20 07-10-2013 11:38 AM
Axial scx10 dingos in the sun crazycrawler94 Videos! 3 04-10-2012 02:03 AM
Axial scx10 dingos in the sun crazycrawler94 Scale Videos! 0 04-01-2012 03:26 PM
Axial Dingos with GOPRO Hero2 crazycrawler94 Scale Videos! 4 01-28-2012 09:40 PM
Axial dingos having some fun! crazycrawler94 Videos! 9 01-18-2012 12:41 PM
