08-25-2012, 10:47 AM | #41 | |
Quarry Creeper Join Date: Dec 2011 Location: Colfax, NC
| Re: Dual Dingos build thread. First build thread! Quote:
08-25-2012, 02:50 PM | #42 |
Rock Crawler Join Date: Jun 2012 Location: Nevada Desert
I initially ground off a bit of the shock mount attaching flange. It helped a bit but under hard flex I noticed it still had slight rub on the frame. There are a few home built CMS units in the SCX10 section but I went with a unit that comes with a panhard setup from CKRC. It and the 2500 mah 2s Gens Ace lipos are my favorite addition and are all under $20 each.
08-25-2012, 03:23 PM | #43 | |
08-28-2012, 05:32 AM | #44 |
| Re: Dual Dingo build thread-My first build thread
I've started making the brace that will Fit in the body post holes on the rear. Is making the shock hoops stiff a good idea? My thought is yes. I've tried searching for this and I couldn't come up with anything. Appreciate any input.
08-28-2012, 10:15 AM | #45 | |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
The C.O.A.T. SCX10 build It works great. used almost all of the orinal hardware, besides 2skrews and 2 nuts. try It out. doesnt effect any thing. | |
09-01-2012, 08:56 PM | #46 |
I decided the Dingo body needed a grill and head lamps. I plan on using Axial light buckets and the screen covers. I'll make my own lense out of clear lexan. I first tried cutting and trimming to fit inside light covers. Took to long and to much sanding. I remmebered that I had a protractor with points. I then scibed the circle on the lexan and trimmed, much easier. Last edited by juswin24; 09-01-2012 at 09:01 PM. |
09-01-2012, 09:00 PM | #47 |
Now I cut a test hole in some styrene to fit the light bucked and lense cap. I trim the tab that hangs down on the lense caps. This way it will fit flush againest the styrene. |
09-03-2012, 03:53 PM | #48 |
Now that the lense cover fits flush, I needed to make a flat spot on the screw post on the light bucket. Didn't want to cut or remove the screw mount completely. I had to make sure I removed enough for the thickness of the styrene and lexan body. |
09-03-2012, 03:58 PM | #49 |
Wanted to see what it might look like lit up. Leaned it up against a mini mag light. |
09-03-2012, 04:04 PM | #50 |
Here's a test fit on the body. I haven't ream a hole on the body yet. I noticed that the D90's light is off center closer to the grill. My try here I centered it To the light plate. There's still room for 3mm light. Just not sure if I was going to put them. Was trying to be slightly different. |
09-03-2012, 04:05 PM | #51 |
Please feel free to make any comments! Looking for ideas and tips or I hope I'm helping you with your ideas. Thanks.
09-03-2012, 04:13 PM | #52 |
Quarry Creeper Join Date: Feb 2012 Location: Texas - just outside of Austin
I like it... I'd drill 2 more holes for 3 millimeter LEDs and you could have the running light and turn signal too if you look there is probably some good textured styrene you could use for a grill! |
09-03-2012, 04:16 PM | #53 |
| Re: Dual Dingo build thread-My first build thread That's what I was thinking. I'll wait until I get some 3mm LEDs to test fit.
09-03-2012, 09:52 PM | #54 |
Pebble Pounder Join Date: May 2012 Location: California
They look good
09-04-2012, 06:21 PM | #55 |
Bought more goody's yesterday. Should some LED's, resistors and holders coming in the mail in a week or so. Looking forward to installing these. I will tell you guys, whoever said cut up credit card was dead on! I'm just glad I've paid cash for all so far. I told myself when I started to build these I just wanted to have a couple of bashers ready to go. Now I got one going scale really fast. I'm Addict, I have a problem! Time to sell more on eBay!
09-04-2012, 07:33 PM | #56 |
By the time you figure it out its too late |
09-04-2012, 08:30 PM | #57 |
| Re: Dual Dingo build thread-My first build thread Just noticed your location. You born in Texas? I was born here, population was about 1500 in '56 Clarendon Texas Clarendon is a city in Donley County, Texas, United States. The population was 1,974 at the 2000 census. The county seat of Donley County, Clarendon is located on United States Highway 287 in the Texas Panhandle some sixty miles east of Amarillo. Wikipedia Area: 3 sq miles (7.77 kmē) Weather: 77° F (25° C), Wind E at 18 mph (29 km/h), 54% Humidity Population: 2,013 (2011) |
09-09-2012, 05:34 PM | #58 |
Most of the LED's stuff is in. The next day or two ill have some mini toggle switches coming in. I had to go the cheapest route possible due to lack of funds. Total cost less than $20. Screws and servo Y harness was seperate cost. Plenty extra for mistakes. LED's are 5mm which fit all Axial light items on the Dingo. |
09-09-2012, 05:41 PM | #59 |
Got the LED holders mounted for the rear tail lights. Real easy to install. I had the 3 light decal stuck there and I used it as template. Since weather been warm, decals just peeled off easliy. |
09-09-2012, 05:49 PM | #60 |
Finishing up the grill. I moved the light buckets off center to match more the D90 grill. This will give room to install two lights next to the headlamp. I found very thin strips of styrene to lay on grill for texture. This will give some dimension to it. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/398956-dual-dingo-build-thread-my-first-build-thread.html | ||||
I don't want to grow-up, 'caus if I did... DINGO Build - RC Rock Crawlers & Scalers @ URC Forums | This thread | Refback | 03-06-2013 09:58 AM |
Dual Dingo build thread-My first build thread - Similar Threads | ||||
Dual dually project thread... | truckerbuddy2 | 1.9 Scale Rigs | 20 | 07-10-2013 11:38 AM |
Axial scx10 dingos in the sun | crazycrawler94 | Videos! | 3 | 04-10-2012 02:03 AM |
Axial scx10 dingos in the sun | crazycrawler94 | Scale Videos! | 0 | 04-01-2012 03:26 PM |
Axial Dingos with GOPRO Hero2 | crazycrawler94 | Scale Videos! | 4 | 01-28-2012 09:40 PM |
Axial dingos having some fun! | crazycrawler94 | Videos! | 9 | 01-18-2012 12:41 PM |
