Thread: Dual Dingo build thread-My first build thread
Old 08-21-2012, 07:40 PM   #1
Default Dual Dingo build thread-My first build thread
This is officially my first ever build thread. I've been on here reading and studying a lot.
I'm open to any input you might have.
Dual Dingos, Will be using FUTABA 4PL RADIO back up is 3PL
I would also like to say, KC HOBBY, Archdale North Carolina is a great store. They beat just about everybody's online prices. They are very friendly and helpful.
*** UPDATE ***
I've decided to make grill and lamp bezels for both rigs. Bought a bunch of 5mm LED's to install.
Also decided to make wheel/fender wells out of styrene for both rigs.
First build
1.9 flat irons
Axial 1.9 chrome beadlocks
35t RC4WD motor
Tekin fxr
Hitec servo 5995 robot servo
Castle BEC set at 6v
Robinson racing gears in tranny
Axial alum CHUBS and KNUCKLES
Axial driveshaft rings
Cotter key shackles (found here forgot whose idea)
Stick batteries 1800 nihms 2 ea
Second build
1.9 flat irons
Axial 1.9 black beadlocks
35t RC4WD motor
Tekin fxr
Hitec servo 5645
This build will have wheel wells and fancy wiring
Here's first pic to start off the dual build
Last edited by juswin24; 01-23-2013 at 09:11 PM. Reason: Update info on wheel wells
juswin24 is offline   Reply With Quote
Old 08-21-2012, 07:52 PM   #2
Default Re: Dual Dingos build thread.
Took me two or three evenings to build the axles. I should say, I have arthritis and some thumb pain which slows me down. I first installed Axials servo arm because I didn't want to drill out the alum one that came with the servo. I later found out it was a terrible fit. Screw wouldn't stay tight when testing. Also was not a tight fit.
Old 08-21-2012, 08:14 PM   #3
Default Re: Dual Dingos build thread. First build thread!
Here's the rear axle. I started out with the three link set up. I've installed Axial rings and found that the one near the spur gear cover rubs real bad. I later change to stock rings at the tranny connections. I really don't think they were needed up there.
Old 08-21-2012, 08:30 PM   #4
Are you building the two for different purposes or will they be twins?
BubbaEinstein is offline   Reply With Quote
Old 08-21-2012, 09:57 PM   #5
Cool!
Glad to see you started a build thread.
I am looking forward to watching your progress.
OH, and I think it was BubbaEinstein's post were
you saw the shackle idea. I just read a post you put up
in one of his threads
cogfounder is offline   Reply With Quote
Old 08-22-2012, 05:05 AM   #6
They'll be for fun! I live to far from any type competition if there is any at all. I don't know of anything near Greensboro NC. As for twins sort of. Build two right now is getting more details such as wheel wells and fancy wiring. I bought two Dingos so if someone comes over we could have some fun with these. So much more relaxing than my racing days!
Old 08-22-2012, 05:16 AM   #7
Here's a shot os the Aluminum Chubs and knuckles. I found out the hard way that these Axial parts do not come with screws to mount these. I had to order some screws which I got from Tony's screws. He really has good prices. If you run across this I had to order 3 mm x 10 mm metric hex button head. I haven't waterproofed yet. You can see there are two holes on the axle body that needs to be plugged if you stay with the three link set up. I'll be switching to 4 link after running it some. I want to see the differene. I didn't pack the axles, but I did use marine grease.
Old 08-22-2012, 05:19 AM   #8
I first installed the oversize Axail rings and found the one near tranny is too large and rubs the spur gear cover.
Old 08-22-2012, 05:38 AM   #9
Dingo Body mount:
I did a lot research on body mounting and I found people didn't like body showing on top of the body in the front. The rear clips where a pain to use. Velcro mounting didn't seem to hold well in roll overs. I've seen rock crawlers where the body mounts are on the side of the body's. My batteries will be the rails. I have new Tamiya hummer that I've been modifying and saw someone on here that mounted the body mounts out back. Got me thinking of how I could do this. This was first attempt. I found the 90 degree mounts on the parts trees. I ran the screws through the bumper posts. I liked the looks but found that they moved to easily so I added wire to keep straight. I've been advised to add strength around the mounts on the body so it doesn't tear. Will be doing.
Old 08-22-2012, 06:53 AM   #10
I like the way you had mount the body..
SGslow is offline   Reply With Quote
Old 08-22-2012, 07:18 AM   #11
Thanks. I have improved this mount. Will post pics soon. Then I'll have a third revision after that.
Old 08-22-2012, 10:14 AM   #12
Lookin' good so far. I like your detailed pics.
96speedZ28 is offline   Reply With Quote
Old 08-22-2012, 05:04 PM   #13
This is my second revision on the front body mount. I used some light weight aluminum sheet. This allowed me two use two screws to keep body from moving. It also has the clips vertical which I liked because it's easier to put in or remove. The Sheetmetal works but I didn't have away to put in the proper bend. I don't like the rounded corners. I'm going to see if I can make them out of styrene.
Old 08-22-2012, 06:05 PM   #14
For both Dingos I've mounted the batteries on the rock rails. I drilled and counter sunk new holes to line up with the rail screws location. I bought extra Axial battery trays to do this. I used the no slip pad for tool chest drawers. I only use one strap with the pad and nothing moves.
Last edited by juswin24; 08-23-2012 at 05:33 PM. Reason: Added picture battery tray
Old 08-22-2012, 06:21 PM   #15
Thanks. I like it when others do the same.
Old 08-22-2012, 06:25 PM   #16
Status...ADDICTED!
ceedawwg's Avatar
Gonna have to use that body mount technique in the future...great idea
ceedawwg is offline   Reply With Quote
Old 08-23-2012, 05:38 AM   #17
Very good improvment on the mounting, its now strong to hold the body.. I like it. Thanks for the idea.
Old 08-23-2012, 05:42 AM   #18
The electronics are being mounted in the rear between shock towers. I'm using plastic box that futaba receivers came in. Perfect fit and big enough for ESC and receiver. I've added a servo extension cord from receiver to outside of box. Once sealed up I can still remove truck. I want the box to be removable because I have a Tamiya Clod Buster and Hummer that I can move the electronics box to. Since the 4pl and 3pl have model memory it works great and saved me some money for now. The wire was to keep shock towers pinched against the box. I need to make a brace to fit there instead of wire. I found a left over parts tree that will work for this. I'll being making soon and will post.
Old 08-23-2012, 05:46 AM   #19
You can see I've been running this Dingo for a couple weeks now. That's why the NC red dirt. I found that I don't ever use the switch on the ESC. No need to cut off, but I will put it in the box. I'm thinking of painting the bottom half of the box black and leaving the lid clear.
Old 08-23-2012, 08:29 AM   #20
How come there are no pictures of the whole rig with the body on?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/398956-dual-dingo-build-thread-my-first-build-thread.html
Posted By For Type Date
I don't want to grow-up, 'caus if I did... DINGO Build - RC Rock Crawlers & Scalers @ URC Forums This thread Refback 03-06-2013 09:58 AM
Dual Dingo build thread-My first build thread - Similar Threads
Dual dually project thread... truckerbuddy2 1.9 Scale Rigs 20 07-10-2013 11:38 AM
Axial scx10 dingos in the sun crazycrawler94 Videos! 3 04-10-2012 02:03 AM
Axial scx10 dingos in the sun crazycrawler94 Scale Videos! 0 04-01-2012 03:26 PM
Axial Dingos with GOPRO Hero2 crazycrawler94 Scale Videos! 4 01-28-2012 09:40 PM
Axial dingos having some fun! crazycrawler94 Videos! 9 01-18-2012 12:41 PM
