08-22-2012, 09:44 AM | #1 |
Newbie Join Date: Oct 2010 Location: small town
| Any performance benefits to Gear Head’s shock relocation kit? Ok so I have been thinking about trying out this new shock relocation kit for my SCX10. I like the scale looks but are there really any performance benefits or draw backs that this kit has? Last edited by Harley; 08-22-2012 at 03:40 PM. Reason: removing links |
08-22-2012, 09:48 AM | #2 |
Pebble Pounder Join Date: Apr 2012 Location: sa
| Re: Any performance benefits to Gear Head’s shock relocation kit?
You will get increased articulation, which may not always be a good thing. For example, i have a custom mount in my build and i need to limit it because i have more articulation than a comp crawler which is bad for the big body im running. If you have the materials you could simply use angle iron like i did and make it your self.
08-22-2012, 10:05 AM | #3 |
Yeah that’s what I had in mind making it myself. I just wanted to get some opinions from people who have or had something similar to this. I figured that there would be more flex but how much would be the question. I suppose it depends on the size of tires and shocks as well. I pulled my G-Transitions shocks off of my Wraith just to try out on the SCX10 and I have them in the Droop setting. It’s helped a lot with it being top heavy but still has great travel downwards. I will be getting these shocks for the SCX so I am wondering if I relocate the shocks will it lower it too much and cause rubbing again. |
08-22-2012, 11:10 AM | #4 |
It depends on how hight you can mount it, but for me it did lower it quite a bit, so i had to get the 110mm shocks to pick me up high enough. not sure if that helps you or not
08-22-2012, 11:23 AM | #5 |
Newbie Join Date: Jul 2012 Location: Madisonville
The cool thing about the G-Transition shocks is that they are 90mm in droop setting and 107mm in sprung. I guess if I do this I may need to reset them in the rear to sprung so I hope 107mm will be enough………………………only one way to find out lol
08-22-2012, 11:56 AM | #6 |
Let us know what you come up with and some pics would be cool to so we can get an idea of your set up, if possible of course |
08-22-2012, 02:02 PM | #7 | |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: Any performance benefits to Gear Head’s shock relocation kit? Quote:
sure, it looked slightly more scale since that's how you'd see triangulated shocks on a leaf-spring vehicle, but had too many drawbacks for me. the setup isn't really ideal for coilover shock setup and gives you so much flex over stock that you might be finding yourself upside down more than you'd like. also, it negatively affected side-hilling capabilities. this is only MY take from triangulated rear susp - get the kit and see how YOU like it since suspension setup is very subjective to the user. Last edited by Harley; 08-22-2012 at 03:42 PM. | |
08-22-2012, 02:43 PM | #8 |
Well I would post some pics but then I would have to pay (I know not that expensive but still) and I hate dealing with photo bucket. I usually post all my stuff on The Horde RC | Facebook . I’ve been a member here for a while now but I checked those guys out because they are kind of local to me but no one on their site had this kit yet so they directed me here which I thought was cool. Most people would blow smoke up you’re bum trying to make themselves look like they know what they are talking about but they said they didn’t know and that I should check here. PLUS IT’S FREE and don’t have to worry about posting links n all that. |
08-22-2012, 06:52 PM | #9 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
I've seen a well known builder on here describe a similar setup as a floppy mess...like Hefner without the little blue pills floppy.
08-22-2012, 08:56 PM | #10 |
Rock Stacker Join Date: Aug 2011 Location: Union Grove
09-16-2012, 06:21 PM | #11 |
Newbie Join Date: Mar 2011 Location: Dandridge, TN
I got mine yesterday and installed it today. I have a level 3 rc lift kit on it and it seems it is still level with the stock shocks mounted. Going to take it out the week for some hill climbing and some side hills to see how it works so far in the yard I am happy with the articulation. But I would like some feedback from other members to see how it works for them.
09-17-2012, 06:58 AM | #12 |
Rock Stacker Join Date: Jan 2010 Location: CA
I just ordered mine last Friday so it should be here soon to test I'm actually gonna use it for clearance issues since the stock shock towers hit the drop bed hilux body.
09-17-2012, 11:21 PM | #13 |
To answer the OP's question, Yes, it articulates alot more compared to stock setup. It came in today by mail and easy to install if you have the stock shocks and the stock 4link truss.... I have Losi crawler shocks which are wider in diameter and the R2J 4link truss which angles the pumpkin so much that you almost cant mount the locknut at the bottom of the shocks. But with minor tweaking, I was able to make it work, and man this setup works way better than stock setup with the same suspension components. Last edited by liftmys10; 09-17-2012 at 11:23 PM. |
Tags |
axial, scx10 |
Any performance benefits to Gear Head’s shock relocation kit? - Similar Threads | ||||
Gear Head RC SCX10 Rear Shock Relocation Kit | Gear Head RC | Chassis and Suspension | 11 | 01-28-2013 04:08 AM |
Gear Head RC SCX10 Rear Shock Relocation Kit | ridgecrest78 | Axial AX10 2nd-gen | 3 | 08-09-2012 03:14 AM |
***Giveaway*** Gear Head RC SCX10 Rear Shock Relocation Kit! Ends Fri. 6/8/12 | Gear Head RC | Axial SCX-10 | 109 | 06-08-2012 09:13 PM |
Gear Head RC SCX10 Rear Shock Relocation Kit | RPP Hobby | RPP Hobby | 0 | 05-31-2012 02:47 PM |
