08-23-2012, 07:35 AM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: london,England
| Tekin motor probs
Hi if you look at the wheels go forward in bursts then as I increas the speed it shakes I have a tekin fxr 35t motor and stock gears. Axial scx tekin fxr35t - YouTube |
08-23-2012, 08:28 AM | #2 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
| Re: Tekin motor probs
Doesn't look like a motor problem. To me it looks as if you have something binding in the drivetrain. My guess is the angles on the universal joints in the driveshaft are too steep, causing them to hit and bind. This is causing the surging you are seeing. The other possability is the top shaft in the transmission is bent and this is causing the surging you are seeing. Good luck. |
08-23-2012, 12:01 PM | #3 | |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
| Re: Tekin motor probs Quote:
It has to be one of these things causing it. | |
08-23-2012, 08:26 PM | #4 |
Pebble Pounder Join Date: Apr 2012 Location: sa
my output shaft was bent or not fully installed and was causing similar behavior, would be good to verify thats not it.
08-24-2012, 02:56 PM | #5 |
Rock Stacker Join Date: Mar 2012 Location: portland
also make sure there is no water in your foams my cousins had water in his foams and caused the same behavior
Tekin motor probs - Similar Threads | ||||
Tekin tekin 35t hand wound motor | vegas1973 | Electronics | 2 | 08-17-2012 10:22 AM |
