09-05-2012, 10:50 PM | #1 |
Rock Stacker Join Date: Jan 2011 Location: Alberta
| 32 pitch questions
i got some questions for the guys running 32 pitch gears, what was the major reason for switching to them and what kind of out come came of this mod?
09-05-2012, 10:54 PM | #2 |
I wanna be Dave Join Date: Sep 2007 Location: San Tan Valley
| Re: 32 pitch questions |
09-06-2012, 12:28 AM | #3 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
No more spending money on little spur gears. It also changed the sound, makes it sound like it has more a$$ I highly reccomend 32p |
09-06-2012, 11:07 PM | #4 |
good to know, this has me excited now! what are you guys running for brands of gears?(havent had much luck with robinson racing in my slash 4x4)
09-06-2012, 11:29 PM | #5 |
09-08-2012, 12:10 AM | #6 |
09-08-2012, 07:47 AM | #7 |
09-10-2012, 10:58 PM | #8 |
thanks for the good info on this, i took the plunge on sat and bought the parts, running 9 tooth on pinion and 54 spur of course. 21.5 novac is not bad on speed but i have noticed some other new issues with this set up. im not to sure if its just working better or what but i came off of a 14 tooth and 87 48 pitch so close to the same ratio... i set slipper to where i normally set it and it slipped 7 times tonight. cant figure it out. i was on greasy ground too. i cant see raising the ratio up any more will help at all. any info will help out alot
09-11-2012, 06:40 AM | #9 |
Newbie Join Date: Feb 2012 Location: -
Anybody using a 58t?
09-11-2012, 05:06 PM | #10 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: 32 pitch questions Slippers do wear and slipper springs do weaken a bit with use. Plus, the more they slip, the worse they get. Crank it down a bit more or try another slipper pad.
09-11-2012, 05:11 PM | #11 |
09-11-2012, 06:16 PM | #12 |
RCC Addict Join Date: Mar 2009 Location: hawaii
09-11-2012, 09:46 PM | #13 |
Rock Crawler Join Date: Jun 2010 Location: UTAH COUNTY
What part # is the traxxas 32p 64t spur that will fit the scx10 transmission?
09-11-2012, 11:25 PM | #14 |
new pads are on and set nut is tight and backed off only a quarter turn and im still slipping today... tires have changed today as well. went form weighted 1.9 cut boggers to 1.9 un weighted rocklox's and same issue again. i guess tomorrows adventure is tighten slipper all the way and see how the robinson tranny gears hold up... see a new spur gear in the near future
09-13-2012, 12:15 AM | #15 |
so i found my issue tonigh with my slipping with the new clutch and gear set. i did not think in 1000 years i would ever see the clutch tension spring actually be week.(could be compressed by hand) after all this messing around i would recommend this mod to any one. the 32 pitch even sounds good imo. now just to play with the ratio's...
09-13-2012, 12:31 AM | #16 | |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
| Re: 32 pitch questions Quote:
09-13-2012, 07:42 AM | #17 |
I found a 58t(32 pitch). I put it side by side with the stock 87t(48 pitch) and the 58t looks bigger. I dont think it'll work on mine because with the 87t, it is already really really close to the driveshaft. solitaire, what pinion are you using with the 56t? Thanks guys |
09-13-2012, 11:46 PM | #18 | |
| Re: 32 pitch questions Quote: | |
32 pitch questions - Similar Threads | ||||
32 pitch | caporalwoody | Axial Wraith | 5 | 03-13-2012 07:14 PM |
14t puller should 48 pitch be changed to 32 pitch | catpwred | General Scale Talk | 4 | 06-20-2011 12:33 PM |
thread count and pitch questions? | crawlinlosi | Losi Mini-Rock Crawler | 5 | 03-31-2009 05:49 PM |
What Pitch would this be? | Eclipse | General Crawlers | 7 | 08-13-2006 07:03 AM |
