09-08-2012, 12:32 PM | #1 |
Newbie Join Date: Sep 2012 Location: Erie
| problem with drive shaft binding
Just put new links in an it seem that my truck does not wont 2 go i think it the drive shaft any tip to help me thanks.
09-08-2012, 12:44 PM | #2 |
Pebble Pounder Join Date: Aug 2011 Location: England
| Re: problem with drive shaft binding
are the angles of the driveshafts really steep? If so that could be your problem? Sorry not to sure what you mean, what sound does it make?
09-08-2012, 12:54 PM | #3 |
it's jumping when i push it froward an the sme thing when i push it backwards it's like it does't wont to go anywear.
09-08-2012, 01:11 PM | #4 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
Sounds like the driveline angles are too extreme. A pic would be really helpful.
09-08-2012, 01:19 PM | #5 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
Are they stock scx drive shafts?
09-08-2012, 10:59 PM | #6 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
Does it do this jumping when you're using the controller, or when it's off you're just trying to push it If you're trying to push the rig while it's off, then you have to use some amount of force until you end up turning the motor, so that'd be the reason there I'd think If it's doing it when you're trying to drive it with the controller, then you got a problem |
09-09-2012, 08:07 AM | #7 |
try clocking your axles to see if that stop the binding
problem with drive shaft binding - Similar Threads | ||||
drive shaft problem | mudtruck | Newbie General | 1 | 01-05-2011 03:41 AM |
help with WK drive shaft problem... | wolfen | HPI Wheely King | 10 | 02-17-2010 08:07 PM |
question about drive shaft binding | kroocer | Tamiya CR-01 | 6 | 12-18-2008 06:15 PM |
drive shaft problem | 4x4boy | General Crawlers | 8 | 11-15-2007 05:58 PM |
Ax-10 Drive Shaft Problem | JEEP TJ | Newbie General | 0 | 11-12-2007 09:33 PM |
