09-17-2012, 10:04 PM | #1 |
Rock Stacker Join Date: Aug 2011 Location: Union Grove
| Box for rx and esc
What are you guys using for a small box to mount your receiver and esc in for waterproofing? I've tried to find small food ware containers but even the smallest ones are too big. Just wondering what other people have used
09-17-2012, 10:26 PM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
| Re: Box for rx and esc
Project boxes from Radio Shack work well, some have used the plastic servo boxes you get from new servos (Hitec, Savox, Spektrum, etc...)
09-17-2012, 11:01 PM | #3 |
| Re: Box for rx and esc |
09-18-2012, 07:12 AM | #4 |
Ahh very cool, thanks guys. Thanks for the link too. I'll have to pick one of those up this weekend
09-18-2012, 10:56 AM | #5 |
I joined the Band! Join Date: May 2009 Location: Palm Bay
Question: If your esc is in a waterproof box, could it potentially overheat? I understand wanting to keep it safe from water damage, but wouldnt that just trap the heat in and potentially damage it another way? Just a curiosity that I didnt know the answer to.
09-18-2012, 11:23 AM | #6 | |
Quarry Creeper Join Date: Dec 2011 Location: Colfax, NC
| Re: Box for rx and esc Quote:
09-18-2012, 12:51 PM | #7 |
I run a tekin rs with a brushed motor on 3s in 2 balloons, in a ratshack box. The outside of the box gets slightly warm, 70f max. Keep in mind the bec is only running a servo winch and the rx also. These are crawlers/scalers, electronics and motors shouldn't be stressed at all. |
09-18-2012, 01:07 PM | #8 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
I run stock AE-2 ESC in a sealed project box (with liquid electrical tape on seams) and have not noticed it overheating at all. The box does get a little warm, but nothing I'd consider hot or a potential problem. I'm sure that with some ESCs and varying electronics setups it is definitely possible to overheat inside of a sealed box.
09-18-2012, 01:09 PM | #9 |
Ok... Im still learning the crawling side of RC. All my go fast stuff, the motors got hot to touch and needed good ventilation. My current setup is still stressed a bit, but thats because Im using leftover stuff from my Slash/Stampede. Eventually I will get more crawler oriented stuff, but for now, this is what the budget allows, so it's all I have to go by. Trying to learn from others without the proper equipment or experience to compare to is fairly confusing sometimes. Thanks for the answers.
09-18-2012, 01:12 PM | #10 |
Quarry Creeper Join Date: Feb 2011 Location: Las Vegas 89121
Before you seal it in a box, check it out, run your crawler and then check to see how hot everything gets. Most crawlers that are set up well don't get real hot. But a little extra room is better than stuffing everything in a small space.
09-18-2012, 02:03 PM | #11 |
RCC Addict Join Date: Jul 2011 Location: Orlando
Just don't do what I did. Removed my MMP from a Radioshack project box to redo the waterproofing and put the ESC in a balloon. All was good except I forgot to unplug the fan on the ESC and it toasted the ESC . Expensive lesson. Sent from my Samsung Galaxy Note (Phablet) |
09-18-2012, 07:31 PM | #12 |
Quarry Creeper Join Date: Jan 2012 Location: Central Florida
You can also take the esc apart and plasti-dip the circuit board,leaving the heat sinc exposed. After you let dry and put back together its good to go. |
09-18-2012, 07:38 PM | #13 |
Newbie Join Date: May 2012 Location: Somewhere
Racers are on the throttle alot more than crawlers. That's where most of the heat comes from. Crawlers MIGHT use full throttle for a second or 2 to help them over an obstacle and that's about it.
09-18-2012, 07:46 PM | #14 |
Agreed.
09-18-2012, 07:47 PM | #15 |
Newbie Join Date: Sep 2012 Location: black diamond
id plasti dip it all...looks a lot cleaner when your done. RC ADVENTURES - Waterproofing RC, CHEAP! Example Model: Axial SCX10 RC Truck - Tutorial - YouTube |
09-22-2012, 05:45 PM | #16 |
Rock Crawler Join Date: Mar 2011 Location: hampton
i closed mine up in a radio shack box and it would thermal. ended up painting it with liquid electric tape
09-22-2012, 06:44 PM | #17 |
Rock Crawler Join Date: Oct 2011 Location: Canada
I've had my stock AE-2 in a radio shack box since day 1. It is taped to the lid, hanging upside down in there, so if and water did get in it wouldn't settle on it. It has never thermaled on me before, or ever even heated up! My recievers are in baloons in the stock reciever cases (x2 ballons and zip ties).
Box for rx and esc - Similar Threads | ||||
question about repossitioning the esc/reciver box | wmax99 | Axial Wraith | 6 | 08-13-2012 07:43 AM |
ESC in a box | USMCrawler | Electronics | 2 | 12-08-2011 08:15 PM |
ESC in a project box question. | DaveinSac | Axial SCX-10 | 3 | 10-05-2011 10:33 PM |
Waterproof ESC box - especially for us in the UK (pics) | MUD4FUN | General Crawlers | 4 | 09-22-2004 07:00 PM |
