10-03-2012, 02:56 PM | #1 |
Pebble Pounder Join Date: Sep 2012 Location: Germany. U.S military post
| Whats the best shock out
Hello everyone. Im new to rock crawling. I have an scx10. Stock I removed the oil and removed bumpstop. But i dont have much flex And ive seen some pics on here with some crazy flex. I want to get the most flex posible . So far im down to HR shocks or gmade shock. But. Looking for other opinions |
10-03-2012, 04:41 PM | #2 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| Re: Whats the best shock out
soft shock setup = torque twist... don't get too hasty, i did, and way to much torque twist. If you want to get max flex, get the gear head rc rear shock relocation kit, but make sure the shocks are close to the stiffness in the front. To avoid torque twist. But this is just my expirience talking. Oh ya, and make sure to put the dang oil in!
10-03-2012, 05:59 PM | #3 |
Pebble Pounder Join Date: May 2011 Location: The Wizzle, MA
I got a set of T-Maxx shocks made by Associated. They're barely a quarter inch longer than the stock SCX-10 shocks, but have the same amount of travel as an AX10/Wraith shock. You can set them soft so they keep the ride height low, but they'll stretch like mad when you need to flex. That, and they come in sets of 8 so you can do 2 rides with one set or sell the other on eBay to recoup some $$. I'm not saying they're the best, but they're the best I've found. |
10-03-2012, 06:04 PM | #4 |
10-03-2012, 08:17 PM | #5 |
RCC Addict Join Date: Jul 2011 Location: Orlando
Doing the GearHead relocation in the rear helped a ton. But like some said it will take some fine tuning to avoid a lot of torque twist. I also just ordered GMade PiggyBack shocks for the front and a set of aeration shocks for the rear. Hope they work good should have them here by the weekend. Sent from my Samsung Galaxy Note (Phablet) |
10-03-2012, 08:18 PM | #6 |
Here are the shocks. Sent from my Samsung Galaxy Note (Phablet) |
10-03-2012, 08:20 PM | #7 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
when i had my scx10 last year....i used Tmaxx 100mm shox
10-04-2012, 01:10 AM | #8 |
I heard with the shock relocation kit. You cant ise a 4link!!!
10-04-2012, 01:44 AM | #9 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
| Re: Whats the best shock out stock shock. stock mounting locations plenty of flex... |
10-04-2012, 03:25 AM | #10 |
10-04-2012, 03:40 AM | #11 |
Pebble Pounder Join Date: Apr 2007 Location: va beach
I might be wrong but the gearhead kit wasn't designed to give you more articulation it was designed to give a scale look while also letting scalers run a drop bed set up.. The fact that is gives you more articulation is because it angles your shocks. 90degree stiff 45degree soft I've seen people run the level3 lift kit sideways which allows them to angle there shocks and gives room for tuning... With that said I don't run either kit and my suspension is similar to the man above... |
10-04-2012, 06:30 AM | #12 |
Pebble Pounder Join Date: Aug 2012 Location: Finland
How are the Proline scaler shocks and are they about the same height as stock dingo?
10-04-2012, 06:47 AM | #13 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
Noob here!!! Im running custom (homemade) relocation bracket 100mm G-made in rear & 90mm front...mounted shock to existing diff screw on axle(no brackets!!!} tons more flex!!!
10-04-2012, 06:49 AM | #14 |
Love sight btw!!!! Just like naxja forum 1:1 all knowledge u ever need at fingertips
10-04-2012, 02:47 PM | #15 |
Newbie Join Date: Feb 2011 Location: Santa Rosa
| Re: Whats the best shock out |
10-04-2012, 03:04 PM | #16 | |
| Re: Whats the best shock out Quote:
Anyways most shocks will requir a little fine tuning with either different springs or different weight oils and such to achieve the right mix between hard and soft. Middle of to much or to little flex..... I know my stock shocks have worked pretty well for the TTC I have entered but it all depends on the rest of the rigs lay out, battery mount, mirrored trans, size tires and wheels.... those kind of things make a big difference to each setup. | |
10-04-2012, 03:09 PM | #17 |
10-04-2012, 03:13 PM | #18 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
I used Traxxas 4761 shocks. They are old school aluminum shocks that predate the traxxas big bores. I really like them. They look ok, and the stock scx10 springs work fine on them. Side by side with stock installed ( i removed the preload clip after) |
10-04-2012, 03:13 PM | #19 |
Quarry Creeper Join Date: Mar 2010 Location: Atlanta
| Re: Whats the best shock out Are you running these? How are they? I have heard the 103mm is a bit much for the SCX-10. I'd like to keep stock height, a little bit more travel, and be able to hit the bumpstops before a wheel comes off the ground. The stock Axial shocks are great, but look kind of cheap. Hows the fit and finish of the gmade?
10-04-2012, 03:17 PM | #20 | |
Whats the best shock out - Similar Threads | ||||
whats the point of this shock set up? | m1009cucv | Axial SCX-10 | 10 | 09-16-2012 06:36 AM |
whats a good shock setup? | ninetwofiveRC | Venom Creeper | 5 | 02-08-2011 06:11 PM |
What works for you? Whats your shock setup? | jeepfreek | Venom Creeper | 19 | 01-27-2010 07:45 AM |
whats the best way to limit a shock? | Mac10 | General Crawlers | 10 | 08-04-2007 12:58 AM |
whats the piece that you use to mount shock | wana crawler | Tamiya Clod Buster | 13 | 07-17-2005 11:56 PM |
