10-05-2012, 08:28 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: Doylestown
| Knuckles rubbing Beadlock screw??
Just installed a pair of aluminum knuckles i bought off another member, not branded. I swapped my kit plastic wheels for my other Axial Beadlock 1.9's and the screw heads hit the knuckle!!?? Becuae of this I can't use this wheel set. Any suggestions??? I assume this has happened to someone else...hopefully Thx for any help
10-05-2012, 09:05 PM | #2 |
Pebble Pounder Join Date: Nov 2009 Location: Paulding
| Re: Knuckles rubbing Beadlock screw??
Take the factory beadlock screws out and get some flush screws and that should fix it
10-06-2012, 01:14 AM | #3 |
Pebble Pounder Join Date: Jul 2010 Location: malta
or use a wider hex
10-06-2012, 08:48 AM | #4 |
Ok... I would like to do the wider hex, need to find some first. Thx for the suggestions
10-06-2012, 09:05 AM | #5 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
Slash front hexes are pretty wide. Or if they aren't rubbing too deep just shave a bit off the knuckles.
10-06-2012, 09:07 AM | #6 |
Ok I'll look into the hexes. I may be able to shave a notch with my dremel I guess
10-06-2012, 02:38 PM | #7 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
The cheap steering knuckles do this, to solve it i used wider stampede hex's and dremeled a small notch in the knuckle for the screws to clear, my truck has been setup this way for 3 years at least
10-06-2012, 08:21 PM | #8 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
I countersunk the screw holes and used countersunk screws - quick, simple, and I didn't have to widen the track width.
Knuckles rubbing Beadlock screw?? - Similar Threads | ||||
Axial 1.9 beadlock screw size? | theone13 | Tires and Wheels | 10 | 12-10-2019 11:15 PM |
screw size for titus beadlock | slashkiller | Tires and Wheels | 2 | 02-27-2012 06:11 PM |
Looking for beadlock ring screw size | Moondo | Losi Mini-Rock Crawler | 6 | 12-19-2009 06:08 AM |
Cheyenne Beadlock screw size? | rcr3fan29 | Tires and Wheels | 1 | 06-20-2006 09:37 PM |
RPM Clawz rubbing on knuckles. | ccampb04 | Tamiya TLT Crawlers | 4 | 03-21-2005 03:18 PM |
