10-15-2012, 03:05 PM | #21 | |
Pebble Pounder Join Date: Jun 2012 Location: Canby
| Re: What to look in USED SCX-10 Quote:
10-15-2012, 03:20 PM | #22 |
Quarry Creeper Join Date: Mar 2010 Location: Atlanta
FWIW... I purchased a "lightly" used SCX-10. The motor was shot, slipper clutch toasted (slipped going up a incline), bent frame, etc. I paid a whopping $200 and it came the stock ESC and all Spektrum stuff. All said and done it came with a perfect body, 1.9 tires (mismatching) and 5400MaH Lipo. I am happy, I have put a little over $400 into it, and love it every moment. Since I was going to replace everything, I figured buying a used one was the same as buying a brand new one, except I'm not afraid to scratch up the used one.
10-15-2012, 03:56 PM | #23 |
Pebble Pounder Join Date: Sep 2012 Location: Ljubljana, Slovenia
managed to get the grub screw out with a 1/16 ball head driver. but i still cant disconnect the drive shaft , i guess some one used too much loctite on it , ill pop in the freezer for an hour or two to see if that helps . |
10-15-2012, 04:24 PM | #24 |
| Maybe some heat? Try putting some debonder on it. I've had luck with that.
10-15-2012, 05:15 PM | #25 |
i dont have any debonder on hand, option two is to somehow remove the e-ring on the other side , so i can get better access to the shaft. i need to buy some traxxas replacement e-rings though since i only have the smaller tamiya ones.
10-15-2012, 11:31 PM | #26 |
| Take the other side out, remove screw holding plastic driveshaft in. Replace plastic driveshaft and continue . That's what I do.
10-16-2012, 05:59 AM | #27 |
success, it was packed with so much thread lock that it created a ridge on the yoke side . a lot of elbow grease later , its out
