10-16-2012, 08:47 AM | #21 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
| Re: Wroncho build Problems
If you are going to do it that way then I would suggest to do what Zonkerd did. Run a bolt or use spacers to go all the way side to side. With it only spaced out like that, the link mount will flex around a lot and eventually fail. If you run it side to side it will be much stronger. I tried it like Zonkerd has his and it still flexed too much for my taste. I ended up making a bent upper link that mounts in the stock location but bends up and around the driveshaft.
10-16-2012, 09:39 AM | #22 |
Rock Stacker Join Date: Feb 2012 Location: Cororan
Pretty much but I will have to find some way to brace up the chassis more to make it less flesh but with the traxxas drive shaft in the rear will be fine until I get a scx10 transmission case
10-16-2012, 09:57 AM | #23 |
| Re: Wroncho build Problems |
Wroncho build Problems - Similar Threads | ||||
CMaD's Wroncho build. | CMaD | Axial SCX-10 | 25 | 02-01-2014 11:16 AM |
West coast disrtuctions wroncho build | wcdfmt510 | Axial SCX-10 | 15 | 01-26-2012 11:00 PM |
TTC-ish Scale-ish Budget-ish Wroncho-ish Build | Meatwad | Axial SCX-10 | 77 | 01-19-2012 03:00 PM |
Build problems! | Apie | Tamiya CR-01 | 4 | 09-26-2009 08:41 PM |
problems during build-up. | silverbullet | Tamiya Clod Buster | 11 | 03-10-2006 07:14 AM |
