![]() | #1 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
So I'm set on doing the Wraith diff swap on my scx which gear set is the best, what do I need exactly to do it? And do I need to swap the trans outdrives to fit the WB driveshafts? I little help guys my rigs down for the count! ![]() Sent From Outerspace Using my HTC-Freeze Ray Gun |
![]() | #2 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
Are you talking about the ring, pinion, locker, bearings, and WB8 driveshafts? My understanding is those are all the same parts for both rigs. Overdrive, underdrive, heavy duty, stock gears -- all the same part number for both rigs. About the only difference is the axles themselves and the axle housings, c-hubs and knuckles. No need to change anything at the tranny. WB8 driveshafts mount the same as old-style stock driveshafts; just use grub screws instead of the long pin style grub at the tranny. Everything should be a direct fit.
![]() | #3 |
^^that long grub is what im worried about i like the style of pin i have another thread about my headaches with the dual grub screw style so if everythings the same, can i just swap the pinion to have the set screw hole through it, can i just use one of the dual set screws if its still m3 in the trans side so i wont have to swap transmissions? |
![]() | #4 |
ok guys i used the searchy search button and i found i need these 3 parts am i right let me know so i can place my order asap! Axial Steel Outdrive Shaft Set (2) [AXI30435] | RC Cars & Trucks - A Main Hobbies Axial 5x29mm Input Shaft Set (2) [AXI30408] | RC Cars & Trucks - A Main Hobbies Axial 3x2.5x11mm Screw Shaft (10) [AXIA0175] | Hardware & Fasteners - A Main Hobbies |
![]() | #5 | |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
| ![]() Quote:
![]() | #6 |
I'm using stampede half shafts and hardened steel yolks with double set screws I'm guessing the shaft side will slide through the other threaded end, or I can dremel em out a tad ![]() Sent From Outerspace Using my HTC-Freeze Ray Gun |
![]() | #7 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
im sure the scx10 driveshafts dont work, as the steel universal doesnt push up against the bearing enough, whereas it bounces around moving the pinion away from the ring gear.
![]() | #8 |
Why would the pinion bounce around? Isn't that the entire point of the bearings? And the traxxas yolks press right up against the bearing on the pinion shaft side Sent From Outerspace Using my HTC-Freeze Ray Gun |
Scx-10 and wraith axle comparison pictures? | scale4x4 | General Scale Talk | 13 | 06-27-2012 01:00 AM |
