10-18-2012, 04:27 AM | #1 |
RCC Addict Join Date: Jul 2011 Location: Orlando
| UnderDrive and OverDrive Gears????
Those of you who have installed these gears And have any info advice or tips it would be appreciated. Plan to put underdrive in rear and OverDrive in front. Scx10 with VP axle housing. Sent from my Samsung Galaxy Note (Phablet) |
10-18-2012, 09:00 AM | #2 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
| Re: UnderDrive and OverDrive Gears????
no real advice other then just make sure u get the right ones in the right axle. they help out alot on climbing hard to tell in this pic but it is near vertical. with the gears i had no problem climbing up it. without them i couldnt even get half way up before flipping over backwards also notice that the torque flex has been reduced from them |
10-18-2012, 10:23 AM | #3 |
Rock Crawler Join Date: Jan 2007 Location: Tuscaloosa
Buy gears. Install. Easy as that.
10-18-2012, 10:39 AM | #4 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
x3 fairly self explanatory.
10-18-2012, 10:50 AM | #5 |
| Lol.... Easy enough. Will be buying them tomorrow. Thanks Really wasn't looking for a HOW TO.... More of a " is it worth it type thing". Pretty sure I could figure out how to install them..... Sent from my Samsung Galaxy Note (Phablet) |
10-18-2012, 11:08 AM | #6 |
Pebble Pounder Join Date: Sep 2012 Location: Ljubljana, Slovenia
this is my next upgrade for the SCX! thanks for bringing it up
10-18-2012, 01:28 PM | #7 |
Without a doubt worth it. My rig was good until I put the gears in. Now its a beast. Climbs like a mountain goat. It really helps keep the truck from lifting the front end on steep inclines. If you haven't done it mirror the transmission while you are at it.
10-18-2012, 01:34 PM | #8 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
How many option gears are there available?
10-18-2012, 03:11 PM | #9 |
10-18-2012, 03:43 PM | #10 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
Has anyone out there done the under drive in the front only...leaving the rear gear ratio stock?
10-18-2012, 03:46 PM | #11 |
| Re: UnderDrive and OverDrive Gears???? |
10-18-2012, 03:49 PM | #12 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
^^pretty sure he meant overdrive in the front and stock in the rear x2 on that making no sense. |
10-18-2012, 03:51 PM | #13 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
isnt the stock 38/13 and the under-drive 38/13
10-18-2012, 03:52 PM | #14 |
10-18-2012, 04:03 PM | #15 | |
| Re: UnderDrive and OverDrive Gears???? Quote:
That would make them both the same ratio. Here are the ratios and part numbers: Stock 38/13 AX30395 Overdrive 36/14 AX30401 Underdrive 43/13 AX30402 | |
10-18-2012, 04:24 PM | #16 |
Thanks CHUD- that's what I meant...under drive the front and leave the rear stock. |
10-18-2012, 04:27 PM | #17 |
^^OVERdrive lol |
10-18-2012, 04:45 PM | #18 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
Running OD(Front) and UD(Rear) gears... Pros... -These new gears are made out of stronger material then stock making them more durable. -Going up hill: Digs the front tires in to get more traction and rear tires spin slower to be less likely to grab rear traction flipping you backwards. -Going down hill: Drags you a$$ end and makes it a bit more easier to control when decending. -Turning: Increased turning radius because it drags the a$$ end, just like pulling a e-brake in a fwd car. Cons: -Cost -Some people like say its more prodicable with no OD and UD. Here is a video of my C1 Hilux with OD and UD gears. Here is the build thread.... Justin's Street(1.9) Truck: SCX10 Hilux.... Last edited by justinart24; 10-18-2012 at 04:56 PM. |
10-18-2012, 04:50 PM | #19 |
Thanks people my mind is definitely SET.... OverDrive for the Front 36/14 UnderDrive for the Rear 43/13 Along with some Vanquish AX-10 Axles, Axle Trusses, Servo Mount along with my already installed Axial Universals, C-Hubs , Knuckles and upgraded bearings. Truck is definitely getting there. |
10-18-2012, 04:51 PM | #20 |
Yeaa I have heard its almost like having a dig my buddy has his front OD and the rear UD, also paired with high steer knuckles he just blips the throttle a couple times and like clockwork it jumps over with almost no front movement its awesome to watch at a comp Sent From Outerspace Using my HTC-Freeze Ray Gun |
UnderDrive and OverDrive Gears???? - Similar Threads | ||||
Poll, Who wants HD underdrive/overdrive gears | kurtus | Venom Creeper | 105 | 01-12-2014 08:12 PM |
overdrive & underdrive gears... Why? | slashbasher | Axial AX-10 Scorpion | 38 | 08-04-2013 09:21 AM |
No more underdrive or overdrive gears? | C_Money | General Crawlers | 21 | 07-07-2011 11:54 AM |
