10-18-2012, 04:00 PM | #1 |
Newbie Join Date: Sep 2012 Location: missouri
| speed question
Wanting to get atleast 10 mph but I don't want to lose torque.I sometimes run smaller tires.
10-18-2012, 04:02 PM | #2 |
| Re: speed question
Hey AR, can you list all the current specs?
10-18-2012, 04:08 PM | #3 |
| Re: speed question
24t pinion,27t axial motor,82t spur,stock esc.
10-18-2012, 04:43 PM | #4 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: speed question
what type of battery are you running? in general, volting up will give you more top-end without sacrificing low-end torque |
10-18-2012, 05:49 PM | #5 |
| Re: speed question
currently running 3800mah NiMH probably switching to 2s though.
10-18-2012, 06:30 PM | #6 |
| Re: speed question
perhaps someone in the past/future has put a radar gun on an scx10, but a stock rtr rig with 2s will get up to about a jogging pace, which is only around 6mph i'd guess. if you truly want some speed and some crawlability, you need to ditch the axial motor and get a quality motor on minimum 2s LiPo, but 3s will be much faster and more to what you want. i'd look at upgrading to something like a HH motor - his motors generally give more torque for the #turns it's rated compared to other brands - so a 27t HH would have torque like a 35t axial motor, but will have much more speed because less turns. perhaps look at less than 27t for more speed with current setup. upping voltage to 3s will give even more speed to the #turns. i'd recommend you look at some of the builds for some of the go-fast crawlers others have built on RCC to see what people are running and to get some tips. a wraith drivetrain setup might be more to what you need since they generally go much faster with their electronics and gearing setups (also because they have larger tire diameter) keep in mind that with all this extra speed you want to achieve, you can expect to start breaking lots of things that are not yet upgraded, so be prepared |
10-19-2012, 05:33 PM | #7 |
| Re: speed question
Any transmission upgrade ideas?Or just stick with stock.
10-20-2012, 12:17 PM | #8 | |
Quarry Creeper Join Date: Dec 2011 Location: Colfax, NC
| Re: speed question Quote:
You'll want the Harden Diff gear and the idler gear. Depending on tranny you might also need the Output drive or the Axial upgrade one that comes with the Dingo. Last edited by juswin24; 10-20-2012 at 12:21 PM. | |
10-20-2012, 04:33 PM | #9 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
| Re: speed question
Another option to consider is a two speed. I have one in my TF2. It is one of my favorite things about it. Low speed is slower then the axial setup and the high speed is definitely faster. Kind of best of both worlds. I have not run an Axial with a two speed yet (I have 4 SCX's), but after getting a TF2 this summer. I may put a two speed in one or more of them. I think there are a few manufacturers that make two speeds for the SCX. There is the Traxxas 2 speed conversion that people have been doing for a long time. But I think I recently saw a RC4WD 2 speed bolt in for the Axial. I am sure there are others out there. You could have a nice low gear for crawling and a high gear for bombing around. |
speed question - Similar Threads | ||||
speed question | slashinbashin | Axial SCX-10 | 4 | 12-11-2011 07:51 PM |
indeed, another speed control question | phre0n | Electronics | 5 | 10-26-2011 05:02 PM |
speed control question | zr2man | Electronics | 4 | 04-09-2010 08:14 AM |
speed question | BigBoss | Electronics | 5 | 12-03-2009 07:28 PM |
speed question | brickyard | Axial AX-10 Scorpion | 7 | 06-09-2008 04:28 PM |
