10-26-2012, 09:59 PM | #41 | |
I wanna be Dave Join Date: Oct 2008 Location: Golden
| Re: Szczerba's IFS SCX Build Quote:
Currently I have the standard SCX10 Axle truss to mount the upper links, but not screwed into the tube part of the axle. | |
10-27-2012, 10:16 AM | #42 |
Steering mock up round two. Cut up and used an old AX10 battery plate for the vertical mount. Swapped the skid/VP Transmission to the other side. Think this setup might work a little better. Servo drag link length will need to be adjusted later. |
10-27-2012, 10:42 AM | #43 |
looks like you are going to have a hard time turning left. try to rotate your servo horn about 115 degrees clockwise so that it points out from the chassis. otherwise it looks great.
10-27-2012, 12:07 PM | #44 | |
the steering drag link and servo arm angle are key to getting it right. Once I get the lower skid on and the upgraded aluminum steering rack on, I will do the fine tuning. Think this setup is going to work out. | |
10-28-2012, 10:52 AM | #45 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
oooh man cant wait t see this done. though ill be in korea. good luck to ya!
10-28-2012, 11:07 AM | #46 | |
Waiting on parts so I put on some non-slw-modded rear axial 1.9's to bring the rear track width closer to the front. Front with tires is 8 3/4" Rear with tires is 8 7/8" Also turned the rear axle 180 degrees to make it turn the same as front. Axial 4-link just mounted with 2 bolts for now. I can drill the rear beef tubes and mount the outsides of the 4 link mount. | |
10-28-2012, 11:33 AM | #47 |
Pebble Pounder Join Date: Aug 2012 Location: Minneapolis
Looking great man. I'm loving all these IFS/Solid axle builds. I thought your Exo/Wraith turned out great as well. Through one of those Mini Trophy bodies on here and you got something great! |
10-28-2012, 12:07 PM | #48 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
Cool looking build. I'm liking it
10-28-2012, 02:50 PM | #49 | |
Plan is to use the Mini Trophy Truck body. Easily tucks the front tires. Honcho tucks tire but is a little narrower than the Mini Trophy. Just the beginning of it. Got bored today and cobbled it together ALL TEMPORARY. Found the perfect aluminum bracket in the parts bin to hold the steering rack to the IFS for the quick test run. Got a full 2200mah pack through it. Dog bones fell out a couple times but I just shimmed them with orings and limited the steering throw a little bit. Climbs and handles really well. Couple poser shots while crawling. Last edited by Szczerba; 10-28-2012 at 02:52 PM. | |
10-29-2012, 06:26 PM | #50 |
Super short video of some tire tuckin' |
10-29-2012, 08:02 PM | #51 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
How much steering do u get with that bad boy?
10-29-2012, 08:08 PM | #52 |
| Re: Szczerba's IFS SCX Build Right now, the steering is limited by the radio by about 40% or so. The dog bones fall out if I move the travel past that point.. Universals will be here in the next couple days. When those are install I should be have plenty of steering throw. But it steers decent right now with the limiting. |
10-31-2012, 07:14 PM | #53 |
Rock Stacker Join Date: Oct 2012 Location: niagara
great build and great idea. any plans to do an ifs as well and free up some ground clearance ?
11-02-2012, 03:00 PM | #54 | |
Had shoulder surgery on my left shoulder Wednesday but up and around today and got some work done. Got in a order of parts from AsiaTee's. Got here in 3 business days but they forgot to include the Aluminum steering rack . They shipped one out today but it's going to be 5-10 business days for it to get here. Mandatory grinding on the knuckle and lower arm for increased droop. I don't like the one upper turnbuckle. That will need to be beefed up. Steering is better with universals. Geometry will need to be tweaked on the steering. Once my shoulder heals, I will be making a trip to Rootar's for some front bumper/skid and cage work. RS4 chassis was bought for alignment hole references. It will get hacked or just used as a template. Last edited by Szczerba; 11-02-2012 at 03:03 PM. | |
11-02-2012, 03:03 PM | #55 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Rig looks great, hope your shoulder get well soon.
11-02-2012, 03:05 PM | #56 |
| Re: Szczerba's IFS SCX Build |
11-02-2012, 09:21 PM | #57 |
looks good, my asiatees order should be here soon, but only ordered arms. With the AL arms, I think you can get rid of the little brace that you ground back a little. I am probably going to do that with the arms on my IFS. Even with shoulder surgery, you are getting more done than I am with mine.
11-02-2012, 09:29 PM | #58 | |
I could have probably ground a little more off the cross brace but wanted to leave some of it. Don't trust that aluminum! The end of the AL arms (out by the knuckles) are only a few mm thick, hince me wanting to keep a little of the cross brace I grinded on. I had surgery Wednesday. They took out 3/16" of my clavical and then then scoped around my AC joint. My doctor told me to get out of the sling in 24 hours and take the bandages off and start moving it around in 48 hours. This build is part of my therapy. Truck is boxed up and heading up the road a couple hours to get front bumper, sliders and rear tube bed. | |
11-03-2012, 10:06 AM | #59 |
Quarry Creeper Join Date: Dec 2011 Location: Colfax, NC
Your build looks great! Hope you healing goes well.
11-03-2012, 10:08 AM | #60 |
Szczerba's IFS SCX Build - Similar Threads | ||||
JIA's IFS Ultra4 build | JasonInAugusta | Axial Wraith | 839 | 10-17-2014 02:36 PM |
Szczerba's Trophy Truck Build.. With Videos | Szczerba | Non Crawler RC's | 110 | 07-18-2012 09:34 PM |
Was Szczerba's Defender 90 Build. On to the Next. | Szczerba | 1.9 Scale Rigs | 22 | 07-07-2012 05:18 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Street's t4r build(going IFS) | StreetKill831 | Losi Micro-Rock Crawler | 95 | 02-08-2012 07:53 PM |
