11-29-2012, 08:26 PM | #121 |
12-01-2012, 09:18 AM | #122 |
| Re: Szczerba's IFS SCX Build
Setup some Pro-10's to take SLW hubs. Fronts is where I needed a little more width. Rears are still the OEM pin mount hubs. Just had to drill the lug holes with a 1/8th drill bit. Didn't shave the SLW collar off either. Swapped some rings on the MTZ tires. All just mock up and dress up right now. Not the final stages. Still building on it. This truck will have two faces. Two bodies with two different styles. A stock weekend rig and a desert/trophy truck theme. BC Paints! will be handling the Trophy Truck theme. Tips, tricks, hints, suggestions? Last edited by Szczerba; 12-01-2012 at 09:22 AM. |
12-01-2012, 09:39 AM | #123 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
needs more cowbell... |
12-01-2012, 09:58 AM | #124 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
How fast does it go? |
12-01-2012, 10:55 AM | #125 |
| Re: Szczerba's IFS SCX Build |
12-01-2012, 04:35 PM | #126 |
| Re: Szczerba's IFS SCX Build Couple quick IPhone Videos. Tekin 13.5, Mamba Max Pro, 3S Lipo and a 21 tooth pinion. Nice power band and crawling with this setup. I added 2oz of weight to the spare tire to help balance the truck out. Last edited by Szczerba; 12-01-2012 at 04:37 PM. |
12-01-2012, 06:27 PM | #127 |
Whoa |
12-01-2012, 09:26 PM | #128 |
| Re: Szczerba's IFS SCX Build Yep, Get a Tekin 13.5 and Mamba Max Pro if you want awesome wheelspeed with great low end control for crawling. I haven't even put the torque rotor in it yet. Welded up radiator supports. Exo-Radiator with fans and will probably add the Exo Light bar on soon too. Painted up the Dinky RC fuel cell and added some details. Stripped some black coax cable for the fuel fill neck and used 14ga blue wire for the fuel lines. Used some thin steel for the fuel tank access door and some 2mm screws to hold it on. Exo rear light bar and Interior are next. |
12-01-2012, 10:12 PM | #129 |
cool. might have to do that |
12-02-2012, 08:17 AM | #130 |
| Re: Szczerba's IFS SCX Build Thanks. I got the fuel cell here, Fuel Cell (White), at Dinky RC. Then I just used parts I had laying around the shop to detail it out. Painted it Red and then used a silver sharpie to color the steel hold down straps. |
12-02-2012, 08:51 AM | #131 |
im lovin it! very nice job on the dinky fuel cell! gonna be a killer rig when it finished! |
12-02-2012, 08:57 AM | #132 |
12-02-2012, 09:34 AM | #133 |
I think it would look awesome with the exo front light bar! |
12-02-2012, 10:12 AM | #134 |
| Re: Szczerba's IFS SCX Build I have a new in box proline light bar setup for the front. I was going to compare the Exo bar to the Proline bar and see which one i like best. Edit. Proline light bar won't work. Last edited by Szczerba; 12-02-2012 at 11:10 AM. |
12-02-2012, 03:07 PM | #135 |
Added the Rear Light bar mount. Used some RCP Crawlers Fabrication*Tabs* and welded them up. Doing my best to keep the welds looking good. Just using a cheap Flux Wire welder. Have it turned down all the way. Added a back cab screen and put on the Spur gear cover as well. |
12-02-2012, 04:22 PM | #136 |
great job on this thing!
12-02-2012, 04:25 PM | #137 |
12-02-2012, 04:26 PM | #138 |
12-02-2012, 08:44 PM | #139 |
| Re: Szczerba's IFS SCX Build Thanks. Painted the inner fenders and battery tray. Also made a new steering aluminum plate for the new upgraded GPM aluminum steering rack. Everything is pretty solid in the steering department now. Finally broke a front Universal. Must have been getting weak cause it broke doing some donuts on the garage floor. They are only $12 a set but reside in Hong Kong. |
12-02-2012, 10:27 PM | #140 |
sounds like you need to invest in a few sets of uni's... or try some different ones. might be able to find some MIP's.. |
Szczerba's IFS SCX Build - Similar Threads | ||||
JIA's IFS Ultra4 build | JasonInAugusta | Axial Wraith | 839 | 10-17-2014 02:36 PM |
Szczerba's Trophy Truck Build.. With Videos | Szczerba | Non Crawler RC's | 110 | 07-18-2012 09:34 PM |
Was Szczerba's Defender 90 Build. On to the Next. | Szczerba | 1.9 Scale Rigs | 22 | 07-07-2012 05:18 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Street's t4r build(going IFS) | StreetKill831 | Losi Micro-Rock Crawler | 95 | 02-08-2012 07:53 PM |
