12-03-2012, 06:33 AM | #141 | |
| Re: Szczerba's IFS SCX Build Quote:
I inact you as my HPI RS4 4 front universal finder Intern. Report back soon. | |
12-03-2012, 06:22 PM | #142 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
ill get right on that....
12-09-2012, 08:29 PM | #143 |
Sets two and three of universals came in a few days ago. Couple random picture from Bald Knob Lake, AR. Too busy driving to take many pictures. Should have taken some video. This motor/esc combo is the best! Swapped to some different beadlocks (Older Eritex's) for the rok lox's. Did did some wheel trading with Colby. Painted the 5th spare one white. Rok Lox's still seem a little tall for this truck but the change in chassis clearance is noticed. BC Paints! is in the process of painting up a new body for this rig as well. Last edited by Szczerba; 12-09-2012 at 08:34 PM. |
12-10-2012, 07:28 AM | #144 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
What is the stock gear ratio of the HPI diff? Great job by the way! It looks amazing! |
12-10-2012, 08:26 AM | #145 | |
See post #17. HPI diff is same as Axial. Szczerba's IFS SCX Build I am running 43/13 HD's up front and 36/14 HDs out back. Build is moving along slowing. Debating on interior setup now. | |
12-10-2012, 05:26 PM | #146 |
Thanks man! |
12-15-2012, 06:07 PM | #147 |
| Re: Szczerba's IFS SCX Build Yep. Got a Gearhead RC rear 4 link mount. Ordered some MIP front CVDs. I was hoping they were going to be long enough it looks like they are 2-4 mm too short. MIP on left GCM on right. Just short enough to to not work. Beat on the truck pretty good today and whooped up on the outputs and $12 universals. Full speed hill climbin'. These were stock outputs. Last edited by Szczerba; 12-15-2012 at 06:09 PM. |
12-16-2012, 05:54 PM | #148 |
Broke out the welder today since I don't have any replacement front output drives laying around. The back half was not really setup to continue the cage on the rest of the truck. So making the cab portion of this is not going to be 100% geometrically accurate. But hey, none of my builds are 100% accurate anything Still some work left to do. I ran out of dremel sanding drums earlier. In the future: Roof supports, door supports and tying the cage into the front shock hoops or somewhere up front there. And a light bar mount Last edited by Szczerba; 12-16-2012 at 05:56 PM. |
12-16-2012, 06:23 PM | #149 |
muy bueno
12-18-2012, 09:14 PM | #150 |
| Re: Szczerba's IFS SCX Build Si, Si. Mas Updatoes. Made a super simple tube bender from square stock, solid rod and a door roller from the hardware store. Two different rollers fit it. Will tie the front into the shock towers next. |
12-19-2012, 09:29 PM | #151 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
Roll cage work is looking good, is it tube or solid stock?..... |
12-20-2012, 10:13 AM | #152 | |
3/16" Tube using a 80amp FLux Wire Welder. I am getting better. I think I added too much cage and might not be able to get the transmission out easily. Plan on tying the cab to the front shock tower too. If I can't keep front universals in this rig from breaking all the time, I am going to put a solid axle up front. | |
12-20-2012, 08:21 PM | #153 |
little more progress. Front end and light bar mount. Still waiting on output drive cups. |
12-21-2012, 10:31 PM | #154 |
Wonk, wonk, HD Outputs, yadda yadda, more welding, yak, yak, paint, Pictures.
12-22-2012, 04:53 AM | #155 |
Rock Crawler Join Date: Jul 2011 Location: north little rock
Excelent work on the cage. Trucks really looking good.
12-22-2012, 10:36 AM | #156 |
| Re: Szczerba's IFS SCX Build Thanks Michael. Assembled. Still more to do in the future. BC Paints! is working on a paint theme for me as well. |
12-22-2012, 10:25 PM | #157 |
This thing is amazing! You have inspired me to mak my own ifs scx10!
12-23-2012, 06:55 AM | #158 | |
Truck is now 7lbs 4oz after adding the front part of the cage. I used 3/16 Tube. | |
12-23-2012, 11:46 AM | #159 |
| Re: Szczerba's IFS SCX Build Funny you mentioned the weight. I was scanning through the pics and was thinking this thing has got to be approaching 9 lbs. With all that steel, 7 lbs an excellent weight.
12-23-2012, 12:08 PM | #160 |
Hot damn! Nice work, Jabroski! |
Szczerba's IFS SCX Build - Similar Threads | ||||
JIA's IFS Ultra4 build | JasonInAugusta | Axial Wraith | 839 | 10-17-2014 02:36 PM |
Szczerba's Trophy Truck Build.. With Videos | Szczerba | Non Crawler RC's | 110 | 07-18-2012 09:34 PM |
Was Szczerba's Defender 90 Build. On to the Next. | Szczerba | 1.9 Scale Rigs | 22 | 07-07-2012 05:18 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Street's t4r build(going IFS) | StreetKill831 | Losi Micro-Rock Crawler | 95 | 02-08-2012 07:53 PM |
