12-23-2012, 10:08 PM | #161 | |
| Re: Szczerba's IFS SCX Build Quote:
Yea, at busting front CVD's. Broke the new HD output too. These CVD's hold up to full throttle hill climbs? No. These CVD's hold up to street drag racing? No. Guess I could ease up on the throttle, find better CVD's (been looking) or put the solid axle back up front. Going to www.gshobby.com tomorrow to see if I can make some other MIP CVD's work for this front end. They carry alot of sets for different cars/trucks. IFS SCX with Tekin Redline 13.5 on 3s, 21 tooth pinion vs SCX Honcho with Holmes Hobbies can with a 27T Race arm (Mike Manning modified) on 3s, 21 tooth pinion Pulls me off a line a bit but they are close. My rig is 7lbs, my brothers like 5lbs or less http://www.youtube.com/watch?v=q-r0T...ature=youtu.be Last edited by Szczerba; 12-23-2012 at 10:13 PM. | |
12-24-2012, 07:24 AM | #162 |
Ha, I've forgot about that motor. Looks like it still runs OK. I'm assuming you've cut it. Bummer about the carnage. Hopefully you can find something at GS. I've heard the new shop is even more awesomer than the last. |
12-24-2012, 07:40 AM | #163 | |
Chad gave me that nice Cobra lathe at Nats and is sending me a power supply he got for free, soon. He is a nice feller! The new GS shop is in an old grocery store in Barling. It's massive and has a small track back in the stock room. If your on facebook, search for the store, they have pictures up. | |
12-24-2012, 07:50 AM | #164 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
Do you think the combo of ud/od gears might have something to do with going through so many front unis and outputs? I've seen mt2s with much more power not have an issue with the hd outputs. I wonder if you went to matched ratio or just one axle under our over if that would help. I'm still working on the body on my ifs scx, so I haven't been able to run it just yet, but can't see that happening to my truck...
12-24-2012, 07:55 AM | #165 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
if you keep trashing cvds you aint gonna have any monsta truck build $$.. i think monkeyracer maybe onto something with the over/under gears. could be worth a quick swapout to see.. nice job on the welding! |
12-24-2012, 08:16 AM | #166 | ||
I'll have to order up another set of gears. I have the UD, OD's and stock ratios. But no two of the same right now. I have slow crawled this truck, pretty easy and the CVD's didn't last long. So they are really weak or it is the OD/UD gearing. I think the drive cups are getting broke when the CVD shaft breaks and gets bound up. Quote:
Monster Truck build already has $700 in it. And Santa may be helping too. Welding is coming along. The 80amp flux core wire welder does ok but I can burn through if I am not really careful. I am getting better but the black paint covers well. | ||
12-30-2012, 06:48 PM | #167 |
Got bored and cut up the Honcho cab I had laying around. I swapped out to the Underdrive gears front and rear. The truck's drivetrain felt alot smoother. After 20 minutes of light trail driving with a couple blips of the throttle here and there, CVD breakage for 4th time. I have some MIP CVD's but they are about 3mm too short. Only two options for those are to cut/re-sleeve or limit the droop on the truck. The truck crawls and handles great right now, so limiting the front will only hurt performance. Any tips, hints, tricks? ... Last edited by Szczerba; 12-30-2012 at 06:50 PM. |
12-30-2012, 09:46 PM | #168 | |
1. Use MIP CVD's with RS4 drift suspension arms. Pro: stronger shafts, con: narrower width (the drift version is 190 vs 200mm for the evo 3) 2. Sleeve the mips. Pro: stronger shafts, con: time consuming (especially if you break one) 3. Try the stock dogbone. Pro: cheap replacements, con: limited steering, weaker (probably) 4. Reduce the motor. (Drop voltage or raise turns) pro: less breakage, con: less speed or torque. My guess would be sleeved mips would be the best bet. Edit: looking at your bent shaft reminds me of my old cheap Chinese monster truck. I kept bending front shafts, but figured it was the cheap Chinese components. Got better quality bones, still bent. Finally figured out it would only happen at full steering lock. The bone would come out of the cup, and the pin would get caught on the outside of the cup, twisting and bending the bone. Limited the steering and haven't had a problem before I parted it out. On the bench, at full lock steering rotate the drive train and see if the bone is popping out at all. Last edited by monkeyracer; 12-30-2012 at 09:52 PM. | |
12-31-2012, 10:02 AM | #169 |
Thanks for the ideas, monkeyracer. Narrowing the front end with new a-arms is not an issue since I run VP hubs on all my wheels. I am sure which arms to buy to try. HPI made way too many variations of the RS4 for me to keep up with. Do you know the parts/part numbers? I think sleeving the MIP's I have may be the best option right now. Only hurdle will be to find the correct inner diameter tube for the sleeve. I have 3/16' steel tube put it will not work. I will have to do some digging to find something. |
12-31-2012, 09:04 PM | #170 | |
Not sure if there's an aluminum version of these or not though... I won't have my SCX up and running for at least a week or more, so I won't be able to see if I am having the same troubles... | |
01-01-2013, 09:03 PM | #171 | |
i was at Lowe's today and found these tension pins. Ill have to see if i can cut and resleeve/weld using these. Not sure yet. | |
01-01-2013, 09:19 PM | #172 | |
I found out because I got aluminum arms from asiatees.com and realized they would need mods to work... | |
01-02-2013, 02:20 PM | #173 |
Newbie Join Date: Apr 2012 Location: Alma,mi
This is sweet, I want one.
01-13-2013, 10:55 AM | #174 |
Quarry Creeper Join Date: Jan 2012 Location: My house
That's 3s??? Well it is a 13.5 but man I thought u was trying to make a fast truck. Looking good man it's a bad ass rig overall.!!
01-13-2013, 12:50 PM | #175 |
| Re: Szczerba's IFS SCX Build Thanks. I put a 13.5 in to for slow crawling, wheel speed and a little top end. This rig kinda has two faces. Crawler and basher but the front end CVD options won't hold up to high speed. I am finishing up some cut/re-welded CVDs right now. |
01-13-2013, 02:47 PM | #176 |
Pebble Pounder Join Date: Dec 2012 Location: montague
This thing is epic. Nice use of hpi parts to a arm the front. Well done
01-13-2013, 03:27 PM | #177 | |
1. Internal and External Limiting of shocks. See droop note below. 2. 3/16" "tension pins" drilled out with 9/64" bit and welded some MIP CVD's for the HPI RS4. The CVD's needed to be lengthened due to this truck having alot more droop than it's on road cousin. If you are a welder/fabricator, dont look at the pictures below. Only been using this new Hobart 140 for a couple hours and these CVD's were tiny. 3. Poser shots from a 30 minute test session. Holding up good so far. 4. New DT-1 Body painted by Ryan at BC Paints!. Awesome work as usual. HPI DT-1 for Szczerba's IFS SCX-10 Last edited by Szczerba; 01-13-2013 at 03:37 PM. | |
01-13-2013, 04:42 PM | #178 |
That didnt last long. I'm out of options with these front axle shafts. |
01-13-2013, 05:48 PM | #179 |
| Re: Szczerba's IFS SCX Build |
01-13-2013, 05:53 PM | #180 |
| Re: Szczerba's IFS SCX Build I know. About 20 minutes of light trailing riding and then about 10 minutes of light rock crawling. I was being easy on the throttle and not trying to get it bound up. I even limited the shocks in and out to remove the extreme driveline angles. Unless someone has a better option, this truck will be getting a solid axle up front before too long. Too fun of a truck to keep it in the garage. And it's my only scale crawling ride at the moment. |
Szczerba's IFS SCX Build - Similar Threads | ||||
JIA's IFS Ultra4 build | JasonInAugusta | Axial Wraith | 839 | 10-17-2014 02:36 PM |
Szczerba's Trophy Truck Build.. With Videos | Szczerba | Non Crawler RC's | 110 | 07-18-2012 09:34 PM |
Was Szczerba's Defender 90 Build. On to the Next. | Szczerba | 1.9 Scale Rigs | 22 | 07-07-2012 05:18 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Street's t4r build(going IFS) | StreetKill831 | Losi Micro-Rock Crawler | 95 | 02-08-2012 07:53 PM |
