10-26-2012, 11:47 AM | #1 |
Newbie Join Date: Sep 2012 Location: salina
| Mirror Trans.
I've been tryin to find out how to mirror the trans on my honcho and i can't find a thread on how to do it. anyone help me out?
10-26-2012, 12:30 PM | #2 |
Pebble Pounder Join Date: Jul 2010 Location: malta
| Re: Mirror Trans.
Hope this helps. whats it mean to mirror the trans? |
10-26-2012, 12:46 PM | #3 |
Rock Crawler Join Date: Mar 2012 Location: UK, Hampshire
| Re: Mirror Trans.
i done the same to my scx10 and it works heres the link i used Mirror Imaged Transmission |
10-26-2012, 01:49 PM | #4 |
Rock Crawler Join Date: Apr 2009 Location: Pa
| Re: Mirror Trans.
I mirrored mine but eventually put it back to factory. With the front and rear 4 links I used there really was not much if any difference.
10-26-2012, 03:25 PM | #5 |
Newbie Join Date: Jul 2009 Location: Westminster/Walhalla
| Re: Mirror Trans.
If you have the new honcho with the spur gear cover it's not the same as the old guide,and it's also not that simple. You have to make spacers for where the spur cover would go I believe.
10-26-2012, 06:58 PM | #6 |
Rock Stacker Join Date: Oct 2007 Location: MD, USA
| Re: Mirror Trans.
There is a transmission spacer on the parts tree (a relic from the older versions of the kit) that is not used when you use the gear cover and cover plate. If you look at the older versions of SCX10 instructions on the website, you will see which piece I mean. In the original kit, it was a grey aluminum stepped spacer. The plastic version is on the parts tree and is not used in the build. If you got RTR, I am not sure if the spacer is with the parts...? There are also the three 6-7mm 'shims' and they are also on the parts tree and are not used in versions with the gear cover. If you have the SCX10 kit (not RTR), you will have all the parts if you saved what was not used in the build. |
10-26-2012, 08:27 PM | #7 |
| Re: Mirror Trans.
If you have the spur gear cover, you'll need to do away with it and go with the spacers. Easiest way to remember is that the 'axial' on the motor plate needs to face the trans, not outwards. Keep in mind there are alot of situations that the mirrored trans can help, least of which is flat ground throttle punch torque twist. |
Mirror Trans. - Similar Threads | ||||
whats it mean to mirror the trans? | slashbasher | Axial SCX-10 | 28 | 01-06-2016 01:57 PM |
Transmission Mirror help! | ieatfish | Axial SCX-10 | 2 | 03-17-2012 12:56 AM |
Mirror Tranny | DJCrawlin | Axial AX-10 Scorpion | 9 | 11-22-2009 02:16 PM |
Mirror trans?? | Brandon13 | Newbie General | 4 | 02-18-2009 11:34 AM |
mirror trans ? | broncoholic | Axial AX-10 Scorpion | 3 | 12-07-2008 09:43 PM |
