11-05-2012, 08:28 AM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| what is the point of this?
came on a truck i get from cl.. steers ok it seems. sorry for the crappy pic.. thanks
11-05-2012, 08:38 AM | #2 |
| Re: what is the point of this?
That's a CMS (Chassis Mounted Servo) kit with panhard bar. It's really just for scale looks (and points if you decide to comp). |
11-05-2012, 08:57 AM | #3 |
ok got it. its not bolted or anything.. moves on the chassis.. never saw one before.. doesnt seem to good
11-05-2012, 08:59 AM | #4 |
hmm, it should be bolted down.
11-05-2012, 09:01 AM | #5 |
I'm not sure what it bolts to but here's some pics of it. Axial SCX10 Honcho Dingo | Chassis Mounted Servo Kit with Panhard Bar | Scale RC Crawler Truck Parts! [SCX-09 CMSP] - $20.00 |
11-05-2012, 09:29 AM | #6 |
thanks ill tae ka look
11-05-2012, 09:34 AM | #7 |
| Re: what is the point of this? |
11-05-2012, 09:40 AM | #8 |
11-05-2012, 09:40 AM | #9 |
didnt even see that
11-05-2012, 09:41 AM | #10 |
yeas that what it does. no bolts. it floats
11-05-2012, 10:56 AM | #11 |
Quarry Creeper Join Date: Sep 2012 Location: Baltimore
My personal opinion.. but shit floats. Not that you'll actually have a problem with it.. but over long term I can definitely see that thing binding/wearing and eventually failing. |
11-05-2012, 01:22 PM | #12 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
ahh its junk. send it to me. jk. i guess with it floating like that it could work on the dingo or the honcho with out any major changes. just make sure your chassis cross beams are tight and strong. |
11-05-2012, 02:50 PM | #13 |
yeah think im going to put it back to stock
11-05-2012, 07:51 PM | #14 |
Rock Stacker Join Date: Oct 2012 Location: CT
It's a level 3 Rc CMS kit w/panhard bar. It only bolts to the axle and the servo mount just pinches between the frame rails on top.
11-05-2012, 09:17 PM | #15 |
Newbie Join Date: May 2012 Location: Pocono's
A panhard bar is used to keep the axle housing centered under the frame and prevent side to side movement.
11-06-2012, 11:42 AM | #16 |
Quarry Creeper Join Date: Mar 2010 Location: Atlanta
11-06-2012, 12:38 PM | #17 |
Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
It will work with three link suspensions, but the way the suspension is set up in the photo is the wrong kind of three link. Shown is a three link with a wishbone upper. You should run it with two lowers, and one single upper, or with a 4-link. If you run the servo on the frame without a panhard or track bar with a non-triangulated 4-link then the servo may just push the axle to one side when in the rocks rather than steering the tires. If you run the servo on the frame with a triangulated 4-link and no panhard/track bar then bump steer will result (unless the drag link is parallel to the control arms which would be difficult to set up on a scaler or rc crawler)
11-06-2012, 04:01 PM | #18 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
How do you make a triangulated 4-ling setup? Thanks! |
11-06-2012, 06:30 PM | #19 |
| Re: what is the point of this? that's actually a helluva question. but on scale trucks it's pretty easy: four links, two upper, two lower. the triangulated part comes from them mounting at a wider point on one end compared to the other.. uppers must narrow on the frame side while the lowers narrow to the axle side or visa versa. your stock scx10 4 link or wraith 4 link is like this. older scx10's are a 3 link that doesn't require a panhard.. it's more of a 1/4 mile or minitrucker's type of three link but it still works ok on a light little rc truck. |
11-06-2012, 07:36 PM | #20 |
huh. I thought the 3-link required pan hard. Does the stock 3-link need it?
what is the point of this? - Similar Threads | ||||
Do you ever get to the point.... | crash | Chit Chat | 62 | 03-01-2010 09:58 AM |
What's the point,,??? | rmdesignworks | Chit Chat | 12 | 09-16-2009 08:47 AM |
What's the point? | JasonInAugusta | Chit Chat | 6 | 08-07-2006 08:08 PM |
