11-05-2012, 09:47 AM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| waterproofing axles and tranny with grease..
i used lucas red and tacky grease.. just opened the axle.. it washed out somehow.. no clue how . i didnt pack it, bu i coated everything.. so maybe it needs to be packed? there a better grease to use? thanks
11-05-2012, 11:11 AM | #2 |
Quarry Creeper Join Date: Mar 2011 Location: Mn
| Re: waterproofing axles and tranny with grease..
I packed the axle tubes and never had a problem. Red N Tacky is a decent grease to use.
11-05-2012, 12:14 PM | #3 |
ok so do need to pack it thanks
11-05-2012, 12:46 PM | #4 |
Quarry Creeper Join Date: Aug 2011 Location: Spalding, Lincs, UK
I put grub screws in the four link mount holes at either end of the axles if you don't have a four link mount fitted. I found the red n tacky seeping out of these during a run in the sun and the grub screws fixed it right away.
11-05-2012, 01:23 PM | #5 |
Marine grease has worked for me. With beef tubes it's kinda hard to pack the entire axle, but coating all internals is not an issue.
11-05-2012, 01:27 PM | #6 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
i used " grim racer speed grease" from aquacraft. it is used on the flex cable on the nitro boats. with a good coat over the gears and axles i havnt had any issues with it washing off or flinging off. just dont over pack tha tranny.
11-05-2012, 02:49 PM | #7 |
my axles dont have grub screws.. maybe i have older ones.. dont know.. i could try the grim racer grease.. since the red and tacky is gone.. thanks
11-05-2012, 07:57 PM | #8 |
Rock Stacker Join Date: Oct 2012 Location: CT
Marine grease has worked great for me. It's got a thicker consistancy and is waterproof. It is made to withstand water applications.
11-06-2012, 12:02 AM | #9 |
Pebble Pounder Join Date: Sep 2012 Location: Queensland Australia
I use marine grease - it also has anti-corrosion additives
11-06-2012, 04:51 AM | #10 |
ok great ill try some
11-06-2012, 01:09 PM | #11 |
RCC Addict Join Date: May 2011 Location: Utah County
liquid wrench marine grease |
11-06-2012, 01:13 PM | #12 |
Quarry Creeper Join Date: Dec 2011 Location: Fayetteville, AR
Marine grease will have better washout protection than most. I use Lucas Oil Marine Grease - comes in a large tube at Lowe's for like $7. Bought one in November 2011 and still have it today. Fink |
11-06-2012, 04:57 PM | #13 |
I run the Lucas red and Tacky. It lubricates well enough, but doesn't stick to the gears very well. I'd say it's easily displaced. To combat this I've drilled holes in the axle and trans cases for a setscrew so I can regularly grease them with a needle fitting using the same grease gun I use for my 1:1. I give them grease until it oozes out the pinion and axle shaft bearing areas This ensures that the case is full so that there isn't any room for water. It also "purges" any possible moisture out. I'll occasionally add a couple ml dropper full of Lucas gear oil stabilizer to the mix. it makes the grease more flowable and sticks much better to the gears. |
11-06-2012, 05:44 PM | #14 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
MARINE GREASE!!!! No packy packy tho.. Trust me... a lot of drag if packed... a lot of stress on motor...
11-06-2012, 05:45 PM | #15 |
true.. think that why i have binding in my tf2 axle
11-06-2012, 06:20 PM | #16 |
Moderator Join Date: Jan 2004 Location: chicago
i use el-cheapo autozone green grease. i pack the axle tubes all the way to the bearings and pack the pinion side of the diff, leaving the other with some air to prevent too much drag on the drivetrain. never had it wash out, when i crack my axles open it usually looks just as fresh as when i put them together. |
11-07-2012, 02:40 AM | #17 |
Pebble Pounder Join Date: Aug 2012 Location: Finland
I've used Tamiya anti wear grease to seal trans and axle housings, it's good for running a bead around the edges and makes a good seal so dirt stays out.Packing axles full of grease is the stupidest thing ever.
11-07-2012, 06:43 AM | #18 |
Pebble Pounder Join Date: Nov 2011 Location: Muskoka, Ontario
I use Mercury 2-4-C, its a great marine grease and since i'm in the industry it's cheap and I know it works. No melting or oozing in the heat but stinks to high hell.
11-07-2012, 07:21 AM | #19 |
i see nothing wrong packing them... water cant get in if the grease is there
11-07-2012, 08:04 AM | #20 | |
| Re: waterproofing axles and tranny with grease.. Quote:
However, I don't think this as big of a deal for crawlers as it would be for racers. Stress is stress, though. Fink | |
waterproofing axles and tranny with grease.. - Similar Threads | ||||
waterproofing axles on the scx10 | tundrafan01 | Axial SCX-10 | 14 | 04-04-2011 10:41 PM |
Waterproofing - which grease? | sasiti | Axial SCX-10 | 38 | 03-28-2011 10:41 AM |
Diff/Tranny Grease and lubrication. | prioret | Tamiya Clod Buster | 1 | 03-27-2011 10:35 AM |
grease your axles | JesterSpec | General Scale Talk | 1 | 08-06-2010 01:33 PM |
waterproofing axial axles | kalin96 | Newbie General | 13 | 07-05-2009 12:11 AM |
