11-12-2012, 10:44 AM | #1 |
Quarry Creeper Join Date: Nov 2012 Location: Nampa
| Need Answers
I have had my Honcho for about a week now and I am worried about doing the waterproofing tips to do on the esc and servo and i kno what upgrades I want to do but just don't kno what to pick ..... help please
11-12-2012, 10:54 AM | #2 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
| Re: Need Answers
Which waterproofing method were you planning, some are a little suspect I think? Do you plan on running in water? If so you could upgrade that esc to a Holmes BRXL that's waterproof. Personally I would upgrade the steering components...this will increase turning radius and replace some of the weak/vulnerable areas as well. Last edited by Mr.Joshua; 11-12-2012 at 11:01 AM. |
11-12-2012, 11:20 AM | #3 |
| Re: Need Answers
Waterproof grease and plasti dip but I am wanting to upgrade servo to hitec waterproof servo upgrade the shocks ,upgrade the steering knuckles and wheels and tires...
11-12-2012, 11:38 AM | #4 |
| Re: Need Answers
Waterproof grease? In the head of the servo? Go lite with it... Gears don't like to turn with a lot in there. If you get a good enough Hitec, you don't need a waterproof one.. go with 300oz servo or better.. cause until you buy a couple diff cheaper ones or do chassis mounted servo, you will want the torque.. plastic dip works! It makes it submergable proof! Aluminum, chubs an high clearance knuckles. Axial cvd's, for max steering. 1.9 pitbulls are my favorite tire.. start were you break stuff, it will all end up replaced in the end.. |
11-12-2012, 11:47 AM | #5 |
| Re: Need Answers
I won't put grease on the head of the servo I would an o ring
11-12-2012, 12:16 PM | #6 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
| Re: Need Answers
Pull the axles apart anf put some marine grease in them. If its stock honcho, start looking into steering link steel out drives an drive shafts c hubs are most common parts to break. Rock beast , baja claws tsl's an boggers are all good tires. read up on some of the reviews for the wheel tire section
11-12-2012, 12:22 PM | #7 |
| Re: Need Answers
I tore the rear apart last and threw marine grease in it
11-12-2012, 11:14 PM | #8 |
Pebble Pounder Join Date: May 2010 Location: Indianapolis
| Re: Need Answers
+2 on filling the axles with marine grease. It keeps out dirt and grime and sand and crap and makes the axles heavier so your trucks COG (center of gravity) is lower. +2 on being carefull with grease in the servo. I packed grease in one and it wouldn't turn at all!!!! oops. |
11-13-2012, 10:19 AM | #9 |
| Re: Need Answers
I will be doing both but I took awhile for the rear for me
11-13-2012, 07:54 PM | #10 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| Re: Need Answers
plasti dip-spray is what I use for the servo, remember to put an O-ring over the servo horn to keep the water from getting in the gear box. (I forgot to do that, and it ruined my servo...)
Need Answers - Similar Threads | ||||
new**need answers please | twitchie | Newbie General | 8 | 04-16-2011 08:23 PM |
In need of answers | hardhead | General Crawlers | 22 | 11-19-2008 05:46 PM |
timberwolf help/answers | 06yz250f | Newbie General | 1 | 08-01-2008 06:58 PM |
need answers please!!! | big willy | Newbie General | 13 | 04-02-2008 09:02 AM |
i need answers!!! | srobertlaw2003 | Chit Chat | 16 | 08-15-2005 07:56 PM |
