11-12-2012, 05:02 PM | #1 |
Rock Stacker Join Date: Sep 2009 Location: Wilmington
| wraith drive shafts on scx10
can't find any word on this, but will the wraith driveshafts work on an scx10?
11-12-2012, 05:14 PM | #2 |
Rock Stacker Join Date: Oct 2012 Location: niagara
| Re: wraith drive shafts on scx10
not sure if they would, but if youre after an upgrade just get metal ones from one of the sites listed here or even ebay. i grabbed some for a great price and theyre tough as nails
11-12-2012, 07:44 PM | #3 |
Quarry Creeper Join Date: Jan 2010 Location: Lunenburg
Yes they'll work. If you need to trim them down its an easy job.
11-13-2012, 09:36 AM | #4 |
Yes. You just need to make sure your tranny outputs and axle input/pinion shafts have the hole through them to attach the drive shafts. My original scx10 is currently running my wraith shafts. Works great with the short wheel base because with them almost completely slid together they are less likely to twist.
11-13-2012, 09:48 AM | #5 | |
| Re: wraith drive shafts on scx10 Quote:
I agree the holes are a better method of attachment, but not required. | |
11-13-2012, 02:40 PM | #6 |
Pebble Pounder Join Date: Nov 2011 Location: Muskoka, Ontario
Honcho and Wraith shafts are the same, the Dingo uses the shorter shafts but all the parts to make either come with your kit. Had stock shafts on Honcho, replaced with ax10 MIPs, bought Wraith, put MIPs on wraith and wild boar shafts on honcho, easy.
11-13-2012, 02:47 PM | #7 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
they work good. a little too long if you have a shortened wheel base tho.
11-13-2012, 10:55 PM | #8 |
| Re: wraith drive shafts on scx10 Technically no, but it is a far superior design compared to grub screws I can't believe it took them this long.
11-14-2012, 05:55 AM | #9 |
Quarry Creeper Join Date: Sep 2012 Location: Baltimore
| Re: wraith drive shafts on scx10 |
11-14-2012, 08:59 PM | #10 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
I run the WB8's in my SCX. I have them modded with a length of old LNC upper link pressed into the male side to prevent twisting. I also run two female ends with a piece of male in between so that they look more like a solid drive shaft. An HH 35T Torquemaster Pro on 3S and no issues as of yet.
11-16-2012, 01:29 AM | #11 |
Rock Crawler Join Date: Sep 2011 Location: Southern Utah
05-20-2014, 09:32 AM | #12 |
Newbie Join Date: Feb 2014 Location: Clanton
Will the SCX 10 Drive shafts fit the axial wraith?
wraith drive shafts on scx10 - Similar Threads | ||||
scx10 drive shafts | demonut | Axial SCX-10 | 4 | 05-23-2012 05:46 PM |
MIP drive shafts for Wraith | Full_Throttle | South Carolina | 12 | 03-10-2012 09:29 AM |
Wraith drive shafts | Jessf | Axial Wraith | 2 | 12-10-2011 10:00 PM |
Wraith Drive Shafts | craddock35 | Axial Wraith | 17 | 10-20-2011 01:51 PM |
scx10 drive shafts | mikeman84 | 1.9 Scale Rigs | 5 | 10-28-2010 05:18 PM |
