12-03-2012, 12:06 PM | #1 |
Quarry Creeper Join Date: May 2012 Location: Houston
| SCX10 Truggy Frame
I really want to do a Toyota based truggy. Unfortunately for me metal work is not my strong point. I figured I'd post some pics on here and see what happens. There are some talented metal workers on here, this is what I want, who can make it happen?
12-03-2012, 12:42 PM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: orlando
| Re: SCX10 Truggy Frame
Not i , but that looks like a fun build.
12-03-2012, 01:15 PM | #3 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
YOU could make that happen if you really wanted to. your fabrication skills can only go up from here |
12-03-2012, 01:32 PM | #4 |
Dude, I'm like rain man when it comes to metal fab, and a lack of thousands of dollars in metal fab equipment poses a slight problem! |
12-03-2012, 01:41 PM | #5 |
well that's up to you. check the vendor section for people who do regular custom jobs. might be difficult timing-wise with the holiday and new year when i'm assuming business picks up and builders get busy. i'm a DIY kind of person and it really depends on how fancy you wanna get. all you really need is a brazing setup (like auto-ignite mapp gas torch, silver solder, flux, etc), a way to cut metal (dremel, hacksaw, etc.), some files/sandpaper/wire brushes for cleanup, clamps. that's pretty much the basics - maybe $100? if you wanna get more fancy, then a trip to Harbor Freight for a small welder, belt sander, drill press, etc would work on a budget. figure you're gonna spend at least $100-200 minimum to get a custom built cage - so might as well put the $ toward tools that you will most likely use in the future on another rig. |
SCX10 Truggy Frame - Similar Threads | ||||
Who can build me a truggy frame that will bolt to an scx10 or fulll frame? | mtgrizzlymn | Newbie General | 4 | 07-04-2012 11:14 AM |
what all do i need to do to switch from an ax10 frame to an scx10 frame | kennyskalla | Newbie General | 8 | 04-12-2012 07:04 PM |
