Thread: Getting a dingo kit, Do i need anything else? help a noob
Old 12-08-2012, 02:02 PM   #1
Default Getting a dingo kit, Do i need anything else? help a noob
Racing gets old sometimes so im going with an scx10 dingo kit since itll be cheaper in the long run than a rtr honcho even though i like the honcho look better.
As of right now ill be ordering for it:
HH br-xl waterproofed
tekin 35t hd - need to kno what pinion would be good for trailing/crawling
spektrum reciever
I have a servo that im gonna see if it will work, if not what would you recommend thats not super expensive?
Ill be marine greasing the axles and waterproofing the servo and reciever.
Is there anything else im going to need other than tools and paint? Im a noob to scalers and could use the help.
Thanks guys, Cody
Cody318 is offline   Reply With Quote
Old 12-08-2012, 02:06 PM   #2
Default Re: Getting a dingo kit, Do i need anything else? help a noob
Robinson Racing output shaft and idler gear.
Stronger-ish driveshafts, Punisher or MIP are pretty good drive shaft companies.
arctichorse is offline   Reply With Quote
Old 12-08-2012, 04:09 PM   #3
I have a Savox 0251MG servo on mine, works great, just a little noisy. 222 oz-in of torque with it, and I only got it for $40 plus tax here.
canadianbacon is offline   Reply With Quote
Old 12-08-2012, 07:35 PM   #4
heinie_21's Avatar
Cs 170 servo is reasonably priced
Sent from my SCH-I535 using Tapatalk 2
heinie_21 is offline   Reply With Quote
Old 12-08-2012, 09:34 PM   #5
Front and rear beef tubes
HD diff gears
3s lipo
Axial alum c-hubs
Axial high steer knuckles
Axial rear lockouts
Vanquish vvd's
Mip drive shafts
Robinson trans gears
500oz servo
Robotronics servo horn
R2j stainless links
Futaba 3pl
Qs winch
Bec for servo
Bec for winch
20ft of 3/16 tube
R2j 4link truss
Hand bro cms w/ panhard
90mm king shocks
Mayhem eng wheels
Pitbull growlers when released
Heyok winch controller
Hot racing hardened lockers
Hot racing 3 peice skid
Hot racing chassis braces
LOADS OF SCALE STUFF
MOHAVE YOTA BODY SET
dinky yota interior
Dinky's divorced kit setup
Wraith seats
Lots of l.e.d.s
Did I 4get anything?
kaneohecrawler is offline   Reply With Quote
Old 12-08-2012, 10:20 PM   #6
Thanks for the replys guys.
For now i ordered the kit itslef (obviously), robinson tranny gears, hh br-xl, hh 35t, and mip driveshafts.
Will be getting somekinda beadlocks so i dont glue the tires and waste them, prob axials since im a cheapo.
Other upgrades will follow, i have a tendancy to upgrade as far as i can for no real reason other than i get bored with it if i dont.
Old 12-08-2012, 10:22 PM   #7
HD diff gears
3s lipo
Axial alum c-hubs
Axial rear lockouts
Vanquish vvd's
Mip drive shafts
500oz servo
R2j stainless links
Futaba 3pl
Qs winch
Bec for servo
Bec for winch
20ft of 3/16 tube
R2j 4link truss
90mm king shocks
Mayhem eng wheels
dinky yota interior
Wraith seats
Lots of l.e.d.s
Drrrr....uhhhhh....that made my brain hurt, and my wallet
Old 12-08-2012, 11:14 PM   #8
Suck it up!
Duuuuuuuude's Avatar
Learn to make stuff. You will not get a better investment of time or money.
Duuuuuuuude is offline   Reply With Quote
Old 12-09-2012, 11:23 AM   #9
Get 2 pairs of the axial black beadlock wheels they are a couple of dollars cheaper than the silver axial wheels. They function good for cheap. Check to make sure they are tight every time you run it as they will strip out with weight in the wheels. Put weights in the wheels . More in the front than the rears.
im gunna crawl is offline   Reply With Quote
Old 12-09-2012, 02:57 PM   #10
Jus
Dingo kit comes with HD outputs already.
Jus is offline   Reply With Quote
Old 12-09-2012, 04:05 PM   #11
The kit comes with a 20 tooth pinion. That will work well with your hh motor
Treecutter is offline   Reply With Quote
Old 12-09-2012, 10:56 PM   #12
I def would get the axial bead locks there cheap and look great
cowboy_crawler is offline   Reply With Quote
Getting a dingo kit, Do i need anything else? help a noob - Similar Threads
Honcho kit or Dingo kit? profsrkos2012 Newbie General 10 07-23-2012 04:50 AM
wraith rtr/builder kit , ax10 ridgecrest or scx10 kit hocho/dingo xC Pirates Newbie General 9 06-09-2012 06:54 AM
dingo kit vxlblitz Axial SCX-10 5 03-18-2012 08:35 PM
dingo kit cossack Axial SCX-10 2 03-06-2012 03:38 PM
