12-16-2012, 07:56 PM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| Tranny Flip??
Besides the questionable title I have a serious question, kinda noob but I've never understood the trans flip what does it actually do? I've inspected my rig and it looks like the weight is centered on the skid so what does the flip change? I'm running an Robinson stuffed scx trans with a traxxas titan 12t so I can see where I could move the COG around but what actually changes it?? Sent from Outerspace Using My iFreeze Ray Gun |
12-16-2012, 08:03 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Re: Tranny Flip??
If your talking about a mirrored tranny i think it helps with torque twist.
12-16-2012, 08:03 PM | #3 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| Re: Tranny Flip??
Reduces torque twist.
12-16-2012, 08:03 PM | #4 |
Pebble Pounder Join Date: Feb 2009 Location: wilkeson
It helps eliminate torque twist.
12-16-2012, 08:19 PM | #5 |
So is that only for torque twist? Nothing weight or COG related?? Sent from Outerspace Using My iFreeze Ray Gun |
12-16-2012, 08:36 PM | #6 |
As far as I know!!
12-16-2012, 08:40 PM | #7 |
| Re: Tranny Flip?? |
12-16-2012, 08:57 PM | #8 |
Well I ask because I've heard people mention in builds they mirror for forward weight idk hope someone else chimes in that's tested this?? Sent from Outerspace Using My iFreeze Ray Gun |
12-16-2012, 10:39 PM | #9 |
Newbie Join Date: Jul 2010 Location: Tex/ Mex. border by the sea
| Re: Tranny Flip??
Mirror your tran. Puts motor in the passenger side --weight on side of torque twist . Several post on here state how to do it -- if you need help. Did my honcho right from the start. It does help. Not sure about a wraith -- I do not have one. Give it a try. |
12-16-2012, 10:44 PM | #10 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
| Re: Tranny Flip??
Correct...reduces torque twist. It gets the weight of the motor onto the other side of the transmission reducing the amount of lift. I've also done the flip...gets the spur gear towards the front for extra clearance when building an interior. Torque twist is less noticeable on heavier rigs. |
12-16-2012, 10:49 PM | #11 |
Well I have a 3.3 turnigy 2s lipo on my passengers side and with my truck at about 9lbs 6oz maybe that's why I haven't noticed the torque twist?? Sent from Outerspace Using My iFreeze Ray Gun Last edited by Big Tex; 12-16-2012 at 10:53 PM. |
12-16-2012, 10:54 PM | #12 |
Hey josh what's the difference between the 3 options?? Sent from Outerspace Using My iFreeze Ray Gun |
12-16-2012, 11:55 PM | #13 |
When you mirror the tranny you have to pull it apart and switch the input shaft around so it comes out of the opposite side of the tranny from stock. Flipping the tranny you just remove the skid 180 it and reinstall. Flip and mirror is a combo of both.
12-17-2012, 12:08 AM | #14 | |
Sent from Outerspace Using My iFreeze Ray Gun | |
12-17-2012, 12:16 AM | #15 |
| Re: Tranny Flip??
Yeah buddy....that 9# will most likely absorb any torque twist. Well, mirror and flip put the motor on the passenger side. Stock and mirror/flip put the motor on the driver side. Flip and mirror/flip move the spur gear to the front. On a light rig torque twist can be really annoying...getting the weight of the motor on the passenger side helps significantly. This helps quite a bit on an AX10 Far as I know getting the spur gear to the front is just for positioning. You're right about the transmission being centered for the most part. Mirroring it just moves the location off the motor (weight) Last edited by Mr.Joshua; 12-17-2012 at 12:22 AM. |
12-17-2012, 12:22 AM | #16 |
^^sweet! That's what I wanted to know I might do a flip and mirror to make it easier to swap pinions and spurs and get the weight on the passengers side to see of anything changes Sent from Outerspace Using My iFreeze Ray Gun |
12-17-2012, 12:29 AM | #17 |
| Re: Tranny Flip??
That would put the motor back on the drivers side if you are in the U.S. (in the upper right corner of the diagram it shows the direction of the front of the vehicle). You'll just want to flip it (basically rotate 180°] I just flipped mine to get the spur to the front on my 9# rig, it does make it easier to get to the motor/spur for me too. Last edited by Mr.Joshua; 12-17-2012 at 12:31 AM. |
12-17-2012, 12:38 AM | #18 |
I know I just can't see your pic on the thread with my phone while replying so I just said mirror/flip so I'd be right either way winning is winning Sent from Outerspace Using My iFreeze Ray Gun |
12-17-2012, 07:59 AM | #19 |
| Re: Tranny Flip??
Gotcha...have fun |
01-15-2013, 05:10 AM | #20 | |
Pebble Pounder Join Date: Aug 2007 Location: Switzerland
| Re: Tranny Flip?? Quote:
When you mirror the tranny you just mount the motor plate on the other side of the gear housing and change the internals to the other side. So the gear housing and the skid plate should stay in the same possision. Flip is when the skid plate and the gear housing is turned 180°, or am I wrong? | |
Tranny Flip?? - Similar Threads | ||||
Why (not) to do the LCC tranny flip | Olle P | Team Losi Comp Crawler | 34 | 10-01-2012 11:45 PM |
Flip tranny? | Twztid | Axial SCX-10 | 20 | 12-08-2011 10:44 PM |
what do i do to flip the tranny???? | geekfreek95 | Losi Micro-Rock Crawler | 5 | 09-30-2010 07:30 AM |
A flip to the tranny flip. Can it be done???? | torque monkey | Axial AX-10 Scorpion | 7 | 11-13-2008 03:35 PM |
why flip the tranny | cutterman | Axial AX-10 Scorpion | 1 | 11-11-2008 08:17 PM |
