12-17-2012, 05:30 PM | #1 |
Rock Stacker Join Date: Jun 2012 Location: Cincinnati
| Shafts for extended outputs
Does anyone know what drive shafts will work with a honcho wheelbase and the crawler innovations extended transmission outputs? I bought the Ax10 mip shafts and they are too long both front and rear. The stock honcho drive shaft fits the front but the rear bottoms out under full rear compression. |
12-18-2012, 03:34 PM | #2 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: Shafts for extended outputs
since you already have MIPs, you're not going to find any that are better, and you should just mod them to fit. you can trim the male part of the shaft if you need to. or even change you link length.
12-18-2012, 06:43 PM | #3 |
I just bought these BMRC Delrin links and really don't wanna change since my body is for the 12.3 wheelbase. I thought about cutting down the MIPs. Don't they have a coating I'd be screwing up by cutting them. I'd have to cut both ends since they have a lip on the male end that the female end hits.
12-18-2012, 07:47 PM | #4 |
Quarry Creeper Join Date: Sep 2012 Location: Baltimore
Shave the driveshafts down a few mm, reduce suspension travel, extend the wheelbase, sprinkle fairy dust on it or get rid of the long outputs.
12-18-2012, 09:29 PM | #5 |
You can trim them slightly.. But be aware that the female side isn't splined all the way down. The male dig shaft is another option and is a bit shorter... its also on sale over at TCS. Here's a pic of length difference. On sale! HALF OFF! Thunder Tech Racing/MIP Short C-Drive Spline for AX10 with Dig (1 each) #MIP-DS15 - The Crawlers Store LLC |
12-19-2012, 08:28 AM | #6 |
^best bet OP
Shafts for extended outputs - Similar Threads | ||||
Crawler Innovations Extended tran outputs | GravelDuster | Axial Wraith | 8 | 09-23-2012 11:56 AM |
