Thread: Relocating Rear Shocks???
Old 12-19-2012, 11:55 AM   #1
Default Relocating Rear Shocks???
Is it a good idea?? Would i get more articulation??
CamposZac96x is offline   Reply With Quote
Old 12-19-2012, 12:31 PM   #2
Default Re: Relocating Rear Shocks???
If you're just going for articulation, read this:
Axial Racing - Articulation: Pro’s and Con’s
The more angled the shock, the softer it is. So yes, you'll get more flex.
canadianbacon is offline   Reply With Quote
Old 12-19-2012, 12:36 PM   #3
Thanx this what i am talkin about
Old 12-19-2012, 01:06 PM   #4
322
From a cosmetic standpoint you could mount a dropped bed on there without having shock hoops in the way.
322 is offline   Reply With Quote
Old 12-19-2012, 02:10 PM   #5
what do u mean ??
Old 12-19-2012, 02:49 PM   #6
by using this, you can have a functional pick-up bed.
mitchr97 is offline   Reply With Quote
Old 12-19-2012, 06:47 PM   #7
Are there not enough threads mentioning that articulation isnt everything?
Why do people still think scalers should articulate like comp crawlers?
More flex this...
More flex that..
Blahhhhh....
Its koo tho.. you will figure it out one day.
kaneohecrawler is offline   Reply With Quote
Old 12-19-2012, 08:41 PM   #8
i aint doing it at all anymore ...
Old 12-19-2012, 10:32 PM   #9
You can make your own relocation kit. There is a chassis brace at the rear that has holes in it. Cut the rest of the brace off leaving just that. Flip it so the holes are facing the rear and fasten it using the existing holes in the chassis. This is where the upper shocks will mount. Next get yourself some m3x12mm bolts and locking nuts from your local hardware store if yiu already dont have any laying around. While youre at the hardware store pickup some 1x1 aluminum L bracket. Cut these brackets to no larger than a 1/4 inch wide. Drill two holes big enough to slide the m3 bolt through. These brackets will mount in between the link truss and axle. Be sure to slide the m3x12 through before mounting it to the axle. Youre gonna need a spacer. Use the spacer from the original mount. Put these on before the shock goes on. Shock goes on next then the m3 locking nut. Viola you have a shock relocation kit. I bent the bracket out a little bit for a little more clearance between the shock and the axle. You're also go need a spacer for the lower links because the shock will not be there. The bumpstops from the spare parts bag works perfect.
Some pics of how mine turned out.
IMG_20121210_222021
IMG_20121210_221546
IMG_20121210_222302
IMG_20121210_222821
tommyargh is offline   Reply With Quote
Old 12-20-2012, 12:47 PM   #10
Great information! Thanks for the post
gamedad is offline   Reply With Quote
Old 12-20-2012, 03:06 PM   #11
Youre welcome!
Old 12-20-2012, 03:37 PM   #12
I agree too, might have to try this myself looks cleaner looking.
rockycrawler is offline   Reply With Quote
Old 12-20-2012, 04:42 PM   #13
It is much cleaner looking but the only downfall is that it actually raises the ride height a bit unless you run a shorter shock in the rear.
Old 12-20-2012, 05:24 PM   #14
Oh I see, I'm trying to keep my ride height down, good to know though!
Old 12-20-2012, 05:31 PM   #15
Just run a softer spring.......
fla_cracker is offline   Reply With Quote
Old 12-20-2012, 10:33 PM   #16
An internal shock limiter will help also.
I have the king 100's but they are a bit tall but compressed leghth is perfect so I put a piece of tube around the shock shaft under the piston. To limit down travel. There for making the rideheight right where I wanted it withought haveing to sacrafice shock spring tuning.
Old 12-21-2012, 03:36 AM   #17
A droop setup would work as well. I like the clearance though.
Old 12-21-2012, 07:08 PM   #18
I do like the idea and looks good!
2manyprojects is offline   Reply With Quote
Relocating Rear Shocks??? - Similar Threads
Relocating Rear Shocks??? CamposZac96x 1.9 Scale Rigs 8 01-07-2013 06:17 AM
Relocating the electronics? Chili Axial Wraith 11 02-13-2012 10:52 PM
Relocating the Shocks PYRO31888 Losi Mini-Rock Crawler 3 10-26-2008 10:31 AM
relocating on/off switch mudrinner4ever General Crawlers 0 08-06-2006 03:01 PM
Relocating the steering? crawlmaxx Traxxas Crawlers 2 09-07-2004 11:34 AM
